Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Tiguan cruise control missing cluster icon, vag code request.
    Hello!
    I've just retrofitted the cruise control on my tiguan my2010, the cc works good, but I only have the green light on the tachometer indicating that the cc is working and I'm missing the speed on the cluster, so can someone with cc fitted and fully working post his vag coding? Maybe I've something wrong or not coded, I think the channels are 01-engine and 16-steering wheel, correct?
    Cheers!
    Dec 2008
    Sydney/Canberra
    Some didn't have it, depends on the year model. Same goes for Golf.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Arrawarra
    Mine's a base model 2010 & has the cruise speed over-riding the odometer readout when in use at the bottom left of the MFD. I do have comfort pack, though.
    Thanks for the info!
    MGV, yours is original or retrofitted?? Do you have a vag to make a scan and post the coding?
    Arrawarra
    Yep, mine is OE. Sorry, don't have a cable for scanning.
    Best of luck getting yours sorted.
    Mackay QLD
    Toki if I remember correctly it is the adaption settings of the #17 instrument panel and as Umai Naa!! said only the recent panels versions support this
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Mmm, it's strange because on various forum I see a lot of cc retrofitted with green light AND icon on MFD on old MY09 tiguan, that's older than mine, so I thought of a wrong coding...
    Today or tomorrow I'll have the chance to check it with vag...
    Cheers.
    Dec 2008
    Alexandra, New Zealand
    I think only the white mdf had this not the red. Certainly my 2008 with red mdf didn't have it and my 2013 with white mdf does !!
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Just to clarify, mine is a white MFD in a 2010 Tiguan.
    I found this thread on the forum that confirm that a 2010 Tiguan with white MFD can do it, the question is how
    Cruise control on the MFD
    Cheers.
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by MGV View Post
    Toki could you post your own VCDS scan? Did you have to change the SWCM to retrofit CC, or did you just swap the stalk to include the CC switches? I have this function working (CC display in white MFD) a base trendline model early 2008 Tiguan TDI in Australia with stock cruise control and all Mk5 electronics, except:
    1) Swapped the SWCM from 1K0 953 549 "BG" version to 1K0 953 549 "CH" version @ SW 0111 (for G85 steering angle sensor near slipring, not in steering rack) for mk6 MFSW Golf GTI retrofit.
    2) instrument cluster swap from 5N0 920 870 D @ SW 2220 (red MFD VDO with micronas chip) to 5N0 920 871 B @ SW 0206 (white MFD VDO with NEC chip)
    Everything else, ie: CECM, CCM, CAN gateway is all low-line ancient mk5 based rubbish.
    CONCLUSION
    • The function must therefore either be coming from SWCM or Instrument Cluster. I never had to do any coding to set this up, it just worked. I get CCdisplay in white MFD with little CC icon, and no more green indicator light in the speedo.
    • All "CH"-version SWCM have SW = 0111 AFAIK according to ross-tech website. I got the CH SWCM from eBay china for AUD$60 posted. Installation required removal of steering wheel IIRC. Link to ross tech: Steering Wheel Control Module Versions - Ross-Tech Wiki
    • Also my 'new' retrofit white MFD SW is 0206 which is the lowest version I have seen for this part number, so unlikely to be SW version issue (though may be entire cluster part number)
    • Perhaps it is due to coding of cluster? Mine is set to "7 - AUSTRALIA", see coding below. I think some regions behave differently, like US setting means you don't get large speed display in white MFD etc. I get the large speed display (need to have Alt. Speed unticked in settings menu) Note: when you change region, sometimes RNS510 radio loses it's coding.
    Tiguan cruise control missing cluster icon, vag code request.-cc_in_mfd-jpg
    MY CODING
    Code:
    Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Component: J0527           056 0111
       Coding: 0001632
       Subsystem 1 - Part No: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H30 0036
       Coding: 00000131
    No fault code found.
    Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
       Part No SW: 5N0 920 871 B    HW: 5N0 920 871 B
       Component: KOMBI         H05 0206
       Coding: 710E00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
