Here's my story of a successful cluster retrofit swap from red MFD to white MFD:
BACKGROUND
- The first Tiguans 2008-2009 came with old mk5 based red MFD cluster. I hate this cluster for it's dim blue lighting and the speedo's weird logarithmic scale that changes intervals half way through at 60KM/H. I just want to drive without going over the speed limit, without having to do maths!!
.- Sometime in 2009/2010 Tiguan electronics were upgraded to Mk6-based: so white MFD cluster, BCM instead of CECM+CCM, etc. I think this was even before official "facelift"?
- If you want to retrofit the Premium cluster with colour display, I read you need an upgraded CAN gateway 1K0 907 530 with version Q or above, or the newer 7N0 907 530 ... gateways. Sorry I don't know the upgrade pathway, I don't have ETKA here. All AUS Tiguans came with at least minimum 1K0 907 530 L gateway so no battery drain issue or errors with this white MFD cluster retrofit or RNS510 retrofit.
PARTS + TOOLS REQUIRED
- New 'used' white MFD cluster from Tiguan, the part number I bought is 5N0 920 871 B. Cost $100 from wrecker. Make sure to match Petrol or Diesel - the tacho range is different. My old red MFD cluster part number was 5N0 920 870 D, Colour MFD clusters have a part number where the second-last digit is an 8, eg: 5N0 920 882
- 2x new glass tranponders IVW D48 for new key, available on eBay $5-10 each. This is not required for white MFD to colour MFD swap, because the existing transponders are compatible with colour MFD. I also ordered 2x brand new key shells from eBay for $8 ea. The existing transponders are glued into the old keys and cannot be removed without risk of damage. This way I put new transponder in new key front, and use old existing remote control (rear portion of key) attached to new key front. The keys/remotes come apart in 2 pieces which is handy (compared to the newer gen keys with the small black logo which are locked down tight, almost impossible to even open!)
- A wiring adapter is required to convert old 36pin black plug -> new 32pin blue plug. Note you don't need this if you are converting from white MFD -> colour MFD. This adapter is expensive because the only way to get an old black plug is from a broken old cluster. They are not available to order separately, whereas the blue plug and pins are about $10 on eBay. Options are to buy adapter online (cost $120+ shipped) from carsystems.pl or get a cheap old red MFD broken cluster online and solder an adapter yourself using pin wiring diagram (cost $20-50 depending on how much for broken cluster). You could also cut the loom in the car for a permanent conversion, but then you can't go back to the old red MFD cluster easily.
- Access to original VCDS, and IMMO tool like AVDI or VVDI or Immo Plus or various other China clones etc
IMMOBILISER
- All current Tiguan incl. 2013 use IMMO4c system (The c stands for crypto I am told) which normally/"officially" requires GEKO system for learning the Cluster-Immo to ECU, as the cluster PIN codes can't be accessed by VW. Latest VCDS software now doesn't even support IMMO4c coding functions because of this (ie difficult to get cluster PIN)
- If doing white MFD -> colour MFD swap, the VW dealer GEKO system should be able to learn IMMO with no problem.
- However in this retrofit, the "official" VW GEKO method of IMMO adaptation always fails because as soon as the VAS diagnostic computer detects the new cluster P/N (white MFD) doesn't match the vehicle (ie it expects an old red MFD) during the "guided flowchart process", it errors out and cancels the procedure before it ever generates the (secret) PIN logins for the clusters (because this is an unofficial retrofit after all)
- "Officially" a used cluster cannot be adapted to IMMO, and also cannot have milage changed once KM>100km. However using an IMMO tool like AVDI (tool costs $10000+ for original) can reset used cluster to 0KM to make it like new, and then you can adjust mileage in VCDS to match the old cluster. Also immo tool can extract the IMMO block from the old cluster in HEX format, revealing all PIN, MAC, transponder IDs etc etc. This data can then be written/flashed in the 'new' cluster, kind of like an immo "clone" in the EEPROM, and then no VW dealer is necessary at all. It all just works!
- In addition, the white MFD immo glass chip key-transponders are not compatible with red MFD transponder. They are the same actual transponder (Megamos TP23/ID48 ) but the newer cluster immo expects some certain vehicle-specific bytes written to the transponder (which is not present in transponders matched to the red MFD). The IMMO tools like VVDI etc have an RFID loop attachment where you insert a virgin transponder and it writes the required bytes into the glass chip and then it can work with the white MFD cluster right away (no need to wait 3 weeks to order a key from Germany, which is what a VW dealer will tell you).
- I didn't require resetting any ABS coding. I read this is often required when IMMO is adapted, but not required here probably because this is a cluster-immo "clone" using the immo tool, and car electronics like ECU and ABS never realise cluster immo is even changed (ie old PIN = new PIN etc).
BONUS
- New white dot MFD works perfect with Bluetooth 9W7 menu and new mk6 MFSW retrofit
- The contrast of the white MFD is much better
- Cruise control now shows a little icon in the MFD with the current CC speed value, and last used CC speed value (so you know what you will get when you press RES to restart the CC, rather than the press-and-pray method of the previous CC display where it was just a little green icon). I am not sure if the new "CH" version SWCM contributes to this. I changed the SWCM from BG to CH with the mk6 MFSW steering wheel retrofit.
A NOTE ON LOST KEYS, CODING etc
- This retrofit proves that GEKO or VW dealer is not necessarily needed to code new keys or adapt immo.
- You just need to find auto electrician/locksmith with know-how I found someone in Melbourne with the proper IMMO tool, also possibly in Brisbane and Sydney. See thread here: Cluster swap - Immo tools AVDI, FVDI, VVDI, IMMO PLUS in Melbourne?
Original instructions (external link) are here: Retrofit Golf 6 Speedometer (white/color cluster) into Golf 5 (Touran, Eos, Octavia and equal) - Tachos / Can Gateways / Airbag-SG - AVDI-FORUM
Adapter pinout if you want to DIY:
Code:NEW BLUE CONNECTOR 32pin | OLD BLACK CONNECTOR 36pin | DESCRIPTION 1 17 Fuel 1 Full 2 18 Fuel 1 Empty 3 16 Fuel 2 Full (4motion) 4 23 Fuel 2 Empty (4motion) 7 7 Tranponder Coil 8 8 Tranponder Coil 11 26 Oil temp 15 22 Brake pad warning 16 19 -Kl 31 Ground 17 34 Washer water warning 18 35 Coolant warning 19 36 Ambient Temp sensor 20 33 -Kl 31 Ground, sensor ground 25 6 Handbrake signal (reversed in Tiguan vs Golf) 26 5 Brake fluid warning 27 25 Oil pressure warning 28 13 CAN high 29 12 CAN low 31 1 + Kl 15 32 2 + Kl 30 (Pin 15 "J533 CAN gateway wake" on old BLACK connector is not used)
