Originally Posted by
Whisp
Hi there,
I too have recently purchased and installed these particular Headlights that Josh has mentioned. Although I can't help with his problem, my question is for Don, who I've seen as kind of a living legend when it comes to coding across many forums.
Firstly I have a Mk7 Comfortline which, as previously mentioned, originally came with Halogens. I have installed Supernova's LED headlights and everything works great out of the box. Sweeping sequential turn signals and all. Now, just to make sure we're on the same page, the light selector switch goes: 0 (off), Auto, Parkers(?), Dipped Beams.
When in the off position, the DRLs are on, full brightness.
When in the Auto position, the low beams are on, regardless of time of day.
When in the Parkers(?) position, the DRLs are on, full brightness.
And dipped beams, normal low beam again.
The factory halogens would, in the Auto position, have a DRL on during the day and automatically switch to low beam at night.
I am looking to regain this functionality with the LED headlights - Full brightness double "U" DRL during the day, automatically switching to low beam at night.
I have tried the "Tagfahrlicht nur in Schalterstellung AUTO" command and set it to active, but as far as I can tell, this only makes it so that in the "0" (off) position, then all lights are off (no DRL). With the Auto position still resulting in low beams during the day.
I saw your advice to change the Lasttyp's to LED, and will try this tomorrow, as it's night now and all testing is moot.
Thanks in advance.
