In a bit of a bind with LED Tail Light Install, please help! :D
Hi Guys,
Never posted here before but I find myself in need of some help. I've installed some LED tail lights in my 2016 MK7 GTI (https://jku.com.au/volkswagen-golf-7...5g1052200.html) using the adapter harness from ECS tuning (https://www.ecstuning.com/b-ecs-part...738ecs01-01kt/) to save myself having to rip the car to bits to use a factory harness.
The coding supplied for VCDS from ECS seems to have only done half the job (clearly the setup between the USDM and AUDM models are different). I now have functional turn signals though the car throws an error whenever they are used. The brake lights are working but not the running lights... which makes it fairly difficult to go anywhere at the moment.
Has anyone had and experience setting this up on and AU delivered vehicle? Alternatively can someone with access to VCDS possibly do me a favour and check what the default values are for the channels listed in the ECS instructions are? I've lost track of the original factory values which will make changing back to the stock tail lights complicated.
I know i'm asking a lot for someone who hasn't posted before but you guys are my best hope :)
