VCDS (VAG-COM) codes and programmable options for Golf Mk7
Quote:
Originally Posted by
DV52
Jimmyjames: OK "Golf Variant" works for me - it looks like this:
Attachment 27404
Kind-of looks like the "station wagon" on your first post. If you check the Codinglog.CSV file that lives in the Ross-Tech/Debug directory on the laptop that you used to make changes, you should see a record of when the change to the code-string was made to the car. Just look for records that have
Address 5F in the first column.
Anyway, try changing the value of these Bytes to
027300 - as per my screenshot
Awesome thanks for that. I think I worked out what I did. I used the long coding helper to deactivate the safety warning.
I think as I was arrowing down through the bytes I must have inadvertently scrolled through the drop downs to select the Variant in the first byte. Anyway I copied the original coding from the log and then changed the 2 to a 0 to disable the warning again. Voila, I have a GTI hatch again on the screen. Cheers!
