Fabromix: As I said in a previous response Rain auto-close tweak is very difficult to get working on a mk7 - but if you want to persist with the attempt to implement the function (good luck), then you could try the following:
If you re-look at the code for your new RLFS, you will see that Byte 0 has a value of hex02 (this is confirmed by the screen shot of Byte 0 in your post). If you had the missing Bit 2 in Byte 0 in your screen and you placed a tick in the box, you would add +4 to the hex value. This would make Byte 0 = hex06 (as per my screen shot from the web).
So - All you have to do is to use the "Open Controller" screen in VCDS and don't select "Long Coding Helper". Simply copy the value in the Current coding box onto the clipboard and paste this value into the New coding box. Then change the 2 to 6 and press doit!. It's that easy - see the picture below:
http://www.vwwatercooled.com.au/foru.../U6WHylm-3.jpg
As for your second question - I don't understand what you mean by "delay ignition car lights"
PS: Sadly, your use of SW version 15.7.3 strongly suggests that you are using a fake VCDS cable. My pet hate on these forums is responding to posts where the cable owner has supported the despicable theft of Uwe Ross's intellectual property. I may be wrong in my belief that your cable is not genuine, so the next time that you seek help, please provide a screen -shot with the current Ross Tech software (which is ver 17.2.4)
