^ Ditto for me for Melbourne or Bendigo
Printable View
Zloybob: A couple of months ago I posted a set of instructions to enable TMC at the following link:
http://www.vwwatercooled.com.au/foru...ml#post1038915
I've tested the tweak and it works OK on my mkVII Golf. Hope it's what you want
Thnx, but im from Russia, and we (in Discover Pro) dont have menu items to activate RDS, AF, TP and etc.
I activated RDS menu with changing longcoding, now need activate TP, and for it im need longcoding of block 5F for compare with my
p.s. sry for my poor english :cookie:
I know that this is a somewhat off-topic, but if I could beg a little indulgence from the moderators, I found the following pic on a VW site in Malaysia. According to the guy who posted the pic (his/her handle is "di3namix"), he was driving a mk7 GTI at the time.
His comments were:"Not quite its top speed, far from it I guess judging from its tall gearing. Car surprisingly stable at these speeds, so much so I drove with one hand and another hand holding my heavy DSLR for this pic."He finished his post with the following wise words:"Note: It still pretty dangerous, hence I won't condone it."I reckon that they are a pretty laid-back lot in Malaysia!!
DV52, looks like you have VCDS? Would you be able to help me with a MK7 R Soundakator mod- I have a screenshot of the coding change required. Send me a PM if this works for you (I am in Bendigo but regularly in Melbourne) cheers :)
Here is the Soundakator mod screen shot
http://www.vwwatercooled.com.au/foru...961ae283-1.jpg
Zloybob: Russia huh? wow this forum sure does get-about!
I've taken a screen shot below of the Hecadecimal coding string for block 5F (Information Elec. control module) on my car (which has TMC activated). Is this what you are after?
Like readerr0r, I would have thought that the long coding sequence from my car would be too different to the coding sequence for the Discover Pro screen. Without knowing either the byte allocation tables or the corresponding functions for every bit in each byte, how will the coding sequence on my car be of use?
Attachment 9579
