Originally Posted by
DV52
^^^ david: thanks for posting up the additional information. A few observations perhaps before we can proceed - it's still confusing (to me, at least).
Your screenshot of the the MIB screen suggests that there is a problem with the AFS but the part of the autoscan for the BCM error suggests that there is a problem with the DRL/Parking light (only the right-side I assume because the screenshot says that there is only 1 DTC). The two are very different. Byte 2, Bits 0-2 also suggest that you have incandescent fittings with bog-standard static AFS. What type of headlight fittings are on your car (I'm not familiar with MY13 GTIs sold in Switzerland)?
Can you provide a full description of the retro-fitted equipment and the coding changes that you made?
