Hey Don,
I just gave your suggestions a shot and I still can't get it working :s
I also tried the outer tail settings on the inner tail settings and couldn't get it to work
Printable View
Hey Don,
I'll need to get back to you with the history report as I'm flying out for work again.
Cheers for the help!
So over the weekend I
Disabled the nag screen
Enabled red fog light flash with high flash
Enabled traffic announcements (even though I live in an area that doesn't get these)
Enabled Fogs as CH/LH
One thing I that I couldn't find, was the option to open the sunroof fully from the key fob. Does anyone know how to do this for a MK7.5 Golf? Right now it tilts.
With the new FL (face-lifted) '18 with LP, is it possible to have the front orange turn signal to blink alone __/__/ instead of both __/__/ and keep three LED ON with White color and only one LED flashing with orange?
\__\__===o===__/__/ <-- only this one blinks (same for other side)
does anyone know how to change the soundactuactor settings? The codes online don't match what is available on VCDS
STF for "soundaktor".
HTH
could someone please confirm to disable the Saftey Nag screen you need to change the actual code to "00"?
