VCDS (VAG-COM) codes and programmable options for Golf Mk7
Quote:
Originally Posted by
DV52
Basik: OK, that's why you were getting the error message to install the activation code - because the 5F module was told that VC was installed (via the code-string setting), but the activation code wasn't entered - makes sense now!
Strange that you still don't have mute after deactivating the Byte/Bit - have you tried resetting the MIBB unit after the change ? It's done like this:
With the MIB unit turned-on press down the ON/OFF knob until the MIB unit switches-off AND keep holding the ON/OFF knob down until the unit turns-on again (about 10 seconds).
Then try the VC button(s) again
Yeah ok so I tried that and nothing changed still get the error message.
http://www.vwwatercooled.com.au/foru...d45aba86-3.jpg
Once I made it deactivated this error has now gone but still get the top message.
http://www.vwwatercooled.com.au/foru...15302f79-3.jpg
This is after the MIB reset as well.
