Rear fog light as #1 in three-step turn signal (?)
I saw the Kencha (sp?) mod where the inner/outer signal rear signal lights alternate - approximating (I think?) the three-step (inner-middle-outer) signal lights, for example, found on recent Mustangs (very cool).
So - I'm wondering if there's a way of coding the rear fog light position on each side (L and R) so that it's "step 1" of a three-step rear signal light.
The way I think you'd have to do it would be to have the rear fog come on and stay on as long as you're signalling, then have the middle come on, then that stays on while the outer also comes on, then the middle-outer go out simultaneously.
Thoughts? Ideas? Suggestions? Mockery? :)
VCDS (VAG-COM) codes and programmable options for Golf Mk7
Quote:
Originally Posted by
Nuje
There is only one fog light at the rear (in AUS anyway. Do NA models have them both sides?), and you'd annoy the cr%# out of the person behind you by blinding them.
That's the only mockery I can manage at this time in the morning :P
The other issue is there are only two phases to the indicator in the BCM that you can code against. Lit or unlit.
This means you can definitely code the fog light to come on when you indicate, and have the inner and outer lights alternate based on the two phases, but you won't be able to code them to extinguish at the same time between cycles. As this would require a third phase.
For example, to achieve what you have described, you would need to code this way:
Lit Phase: Fog on, inner light on, outer light off.
Unlit Phase: Fog on, inner light off, outer light on.
Third phase (doesn't exist): fog on, inner light off, outer light off.
