Nuje: Hi - Allow me to add to agentthumb's excellent response, please.
At a fundamental level, the standard wiring for the two rear fog lights on a mk7 will be problematic to achieve your (interesting) lighting effect. The perhaps not surprising feature about Leuchte programming is that whilst it's possible to allocate up to 8 x different functions to an individual lamp, the instructions from a Leuchte-set are sent to a single pin on the BCM (what VW calls "J519", or the module @ address hex09 on the VCDS autoscan)
As I explain in my Leuchte programming paper, the naming protocol that VW uses for their Leuchte channels identifies which pin on the BCM that will be affected by the setting value. For example, for (4)-Leuchte26NSL LA72-Lichtfunktion A 26, which is one of the channels for the rear fog light(s) - the A72 means that this channel value is allocated to PIN #72 of Socket A on the BCM
So, here's the fundamental problem with your suggestion (and I don't intend any mockery) - the standard wiring arrangement for the rear fogs is as follows:
http://www.vwwatercooled.com.au/foru.../vCy2bKp-1.jpg
Notice that the two rear fog lights are wired in parallel, which means that they share the same PIN on the BCM - which means that there is only one Leuchte-set for both lamps - which means that it's not possible to turn on/off just one lamp at any instance (i.e to make just the left fog light blink - without also making the right side fog light blink)
Alas
PS: Of course, if you were sufficiently motivated, you could re-wire one of the fogs to a spare "Leuchte PIN" on the BCM (there are a small number of unused Leuchte-sets in the BCM) , but then you would need to consider the matters in Agenttumb's response
