Parking light in 3rd break light
Parkinglight in 3rd Brakelight
(16)Leuchte22BR M57-Lichtfunktion G22 > not active > Standlicht allgemein (Schlusslicht Positionslicht)
(17 )Leucht322BR M57-Dimmwert GH22 > 0 > 1
https://www.youtube.com/watch?v=6qBReJktx9Q
Quote:
Originally Posted by
DV52
I've always found the 3rd brake light to be a much undervalued facility on a car. Truth is that on a mk7, it can be used to do all sorts of additional functions (other than just being a brake light). On my highline, the third brake light was factory fitted with an LED.
Here's some options for how the role of the 3rd brake light can be expanded. I discovered these instructions as part of material that I received from a forum colleague (Many thanks -
Morde), who resides in Germany and therefore has access to a richer information base than us English folk (and he understand the German language- which is a great attribute to have when trying to decipher VW's cryptic nomenclature)!
Note: for the three tweaks shown below, the structure of the changes across the Leuchte-set channels (and the non-Leuchte set channels) are arranged so that each individual tweak is independent of the other options. Pick-and-choose whichever tweak that you like (or choose none!),
I implemented all three options on my car this morning and I can vouch that they all work
3rd/High-Mounted Brake Light Tweaks - Instructions
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Standard setting column
- For the wanted options, change the adaptation channels depicted in the table below to the values in the appropriate column (tip: use the "Search" box to locate the channels)
http://www.vwwatercooled.com.au/foru...gO1NKpng-1.jpg
VW Golf MK7 taillight non LED conversion - NAR to ROW - amber turn light
Hi folks
This is my first “post” so hopefully it goes in the right thread..
I have a 2015 E-Golf North American version (NAR) and want to replace the tail light with OEM EURO tail light – NOT LED to get amber turn signal. There are lots of writing on the net about LED conversion but I could not find exactly my problem.
I used this link as guide:
VWVortex.com - LED Taillight Wiring & Coding Thread (North American Golf/GTI)
I have purchased EURO tail light - (outer left and outer right ROW version) and installed them onto the car - no changes to: inner left and inner right tail light.
I only changed the cable pin configuration for the outer tail lights and programmed “leuchte” A71, C8 and C6
My main problem after the conversion: when I hit the brake, both amber blinkers(A71&C8) act as a brake light.
Here is what I did on left side:
Stock outer tail light (NAR) cable has 3 cables/pins:
1. Red (A71) in PIN 1 (combined brake/turn signal/ park…)
2.GND in PIN 2
3. C6 in PIN 4 – Red side marker LED
I repinned the left & right cables to a new configuration to match the EURO outer tail light – non LED and changed values in VCDS
New configuration:
1. Red (A71) into PIN3 (amber turn signal) – programmed A71 as turn signal in VCDS
2. GND stays in PIN 2
3. C6 into PIN 1 to become brake and driving tail light. – (programmed C6 as brake light and park/running light)
Idid the same changes for the right side (C8)
So what is happening on the outer tails.
1. Amber section of the Euro tail light works nice as a blinker(A71&C8) – as it should
But when I hit the brake, both amber blinkers(A71&C8) lights up together with the red brake light in C6, so there is 2 “brake” lights in the outer tail light – one red and one amber.
2. The red section (C6) have some issues also. Light comes on but blink and dies out when turning on the light switch on the dash. If I touch the brake – the red light (C6)will stay on – as they should and they work fine.
(the reason can be two pcs W21W bulbs on the same line(C6) probably solved if I use LED 7440 instead.
So to sum up:Light (A71 and C6) both show the brake light - but A71 is only programmed as turn signal - se coding underneath.
The strange ting is this. The E-Golf has a ECO B-mode (regenerative braking) on the gear shifter.
If the car is in B-Mode it will turn on the brake signal automatically if you lift the foot of the accelerator and when it does – the brake signals works perfect – no light in the amber section (A71) - just brake signal in C6 lamp - so the B-mode understand my programming and repinning of the cable/wires
So everything is working perfect except when I hit the brake pedal.
Is there a problem using Leuchte A71 as a turn signal only? Is A71 & C8 tied to the brake system? - I see other people has shown programming examples A71 & C8 as turn signal, but I do not know if they have had success.
Any idea what I can do to solve the problem?
My hope is to avoid wiring from dashboard/BCM to the tail or open up the hatch and take turnsignal from (C10)
Appreciate if somebody can help.
Here is the coding examples I used (found on the internet)
Turn signal left
(1)-Leuchte20BR LA71-Lasttyp 20 12-Blinkleuchten
(4)-Leuchte20BR LA71-Lichtfunktion A 20 Blinken links Hellphase
(5)-Leuchte20BR LA71-Lichtfunktion B 20 not active
(6)-Leuchte20BR LA71-Dimmwert AB 20 100
(7)-Leuchte20BR LA71-Lichtanstteuerung HD AB 20 Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20 not active
(9)-Leuchte20BR LA71-Lichtfunktion D 20 not active
(10)-Leuchte20BR LA71-Dimmwert CD 20 0
(11)-Leuchte20BR LA71-Dimming Direction CD 20 maximize
(12)-Leuchte20BR LA71-Lichtfunktion E 20 not active
(13)-Leuchte20BR LA71-Lichtfunktion F 20 not active
(14)-Leuchte20BR LA71-Dimmwert EF 20 0
(15)-Leuchte20BR LA71-Dimming Direction EF 20 maximize
(16)-Leuchte20BR LA71-Lichtfunktion G 20 not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20 not active
(18)-Leuchte20BR LA71-Dimmwert GH 20 0
(19)-Leuchte20BR LA71-Dimming Direction GH 20 maximize
Turn signal right
(1)-Leuchte21BR RC8-Lasttyp 21 12-Blinkleuchten
(4)-Leuchte21BR RC8-Lichtfunktion A 21 Blinken rechts Hellphase
(5)-Leuchte21BR RC8-Lichtfunktion B 21 not active
(6)-Leuchte21BR RC8-Dimmwert AB 21 100
(7)-Leuchte21BR RC8-Lichtanstteuerung HD AB 21 Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21 not active
(9)-Leuchte21BR RC8-Lichtfunktion D 21 not active
(10)-Leuchte21BR RC8-Dimmwert CD 21 0
(11)-Leuchte21BR RC8-Dimming Direction CD 21 maximize
(12)-Leuchte21BR RC8-Lichtfunktion E 21 not active
(13)-Leuchte21BR RC8-Lichtfunktion F 21 not active
(14)-Leuchte21BR RC8-Dimmwert EF 21 0
(15)-Leuchte21BR RC8-Dimming Direction EF 21 maximize
(16)-Leuchte21BR RC8-Lichtfunktion G 21 not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21 not active
(18)-Leuchte21BR RC8-Dimmwert GH 21 0
(19)-Leuchte21BR RC8-Dimming Direction GH 21 maximize
This one I modified to c6 from LA72
Brake lights/running lights
(1)-Leuchte26NSL C6-Lasttyp 26 13 - Bremsleuchten
(4)-Leuchte26NSL C6-Lichtfunktion A 26 Brake light
(5)-Leuchte26NSL C6-Lichtfunktion B 26 not active
(6)-Leuchte26NSL C6-Dimmwert AB 26 100
(7)-Leuchte26NSL C6-Lichtansteuerung HD AB 26 Always
(8)-Leuchte26NSL C6-Lichtfunktion C 26 Standlicht allgemein (Schulusslicht...)
(9)-Leuchte26NSL C6-Lichtfunktion D 26 not active
(10)-Leuchte26NSL C6-Dimmwert CD 26 28
(11)-Leuchte26NSL C6-Dimming Direction CD 26 maximize
(12)-Leuchte26NSL C6-Lichtfunktion E 26 not active
(13)-Leuchte26NSL C6-Lichtfunktion F 26 not active
(14)-Leuchte26NSL C6-Dimmwert EF 26 0
(15)-Leuchte26NSL C6-Dimming Direction EF 26 maximize
(16)-Leuchte26NSL C6-Lichtfunktion G 26 not active
(17)-Leuchte26NSL C6-Lichtfunktion H 26 not active
(18)-Leuchte26NSL C6-Dimmwert GH 26 0
(19)-Leuchte26NSL LA72-Dimming Direction GH 26 maximize
