Mark: I'm not sure, but I suspect (guess?) that you haven't managed to include the Blinken Hellphase/Dunkelphase commands into your tweak correctly (or at all) and this is why the inner lamps don't blink!
So, let me invite you to consider the following when designing the Leuchte programming changes for this function:
First - you need to remember that on both sides of the car, the inner tail lamps on a mk7 (for LED fittings) are connected in parallel (electrically), hence they resemble the 3rd Brake light in that there is only one Leuchte-set controlling both lamps. This means that unlike the "pace-car " example, where the blinking activity in the hazard warning light tweak is activated by using the opposite side blinken command. in this instance, both side blinken commands need to included into the same Leuchte-set
Second, The activating Leuchte command (i.e. Aktive Blinkfunktion...) that is used for both the pace car and the 3rd Brake light examples needs to be included into the change sequence for this tweak (illuminated to 100%).
Third - Of course you must have already enabled the
Dyn. turn signal modes-Warnblinken_Zuendung_EIN and
Dyn. turn signal modes-Warnblinken_Zuendung_AUS adapation channels, but I assume that this has been done because you have implemented my 3rd Brake-light and Pace-cae tweaks.
So, putting all this together, the instructions
using OBD11 for
Enabling the Inner Lamps with the Hazard Warning Signal are like this:
- Select the Central electrics module module @ address hex09
- Select Security access
- Enter the magic number 31347
- Select Adaptation
- Search for rc6 and select Leuchte27NSL RC6
- Depending on whether you want to align the blinking of the inner lamps with eith the outer, or inner turn signal, make the changes shown in the screen shots below
