Probably needs adjusting and isn't disengaging the clutch completely.![]()
driving home... went to change gears and then the clutch didn't work...
the cable moves and the lever lifts up and down...the selectors are all working and i can select all gears (when the car is off) and then when it is on i need to rev match and the clutch won't work
any ideas?
seriously nothing is ever going for me...![]()
sound like it may be the pivot on the thrust bearing under the cover at the end of the gearbox.
can you put in gear when engine is not started?
sounds like the pressure plate
