It's the same except you have to unbolt the end cover.
4 bolt's. That's all.
I'd go with Pete's advice first, then go with Dom's throw out bearing advice.
Heap's easier & faster job than removing the box, even though it's only a 30 minute job. haha
Your also working through the "process of elimination".
Don't just dive into the hardest job first.
Release bearing in the outer end of the box I reckon. Easy to check and the one in the 5 speed goes straight in providing the plastic sleeve isnt damaged. Hopefully the pushrod hasnt welded itself to the pressure plate parts.
Andrew
sooo how did it goo with the cable..shift thing....
Audi S3 8L - Stroker GTX3582 700bhp+
Golf GTI 1980
Golf GLS 1979
www.facebook.com/etunersmotorsportau
checked the gearbox today...took the end cap off and all is in order at that end. the lever doesn't actually go up so the rod isn't pushing the clutch in...box out 2moz morning hope its not a new clutch involved...if it is what are they worth???
