Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: problem...again :(
    Eastern suburbs of Melb
    problem...again :( URGENT!
    driving home... went to change gears and then the clutch didn't work...
    the cable moves and the lever lifts up and down...the selectors are all working and i can select all gears (when the car is off) and then when it is on i need to rev match and the clutch won't work
    any ideas?
    seriously nothing is ever going for me...
    Jun 2006
    Orange NSW
    Probably needs adjusting and isn't disengaging the clutch completely.
    i have the clutch cable adjusted as far out as it goes and has 2 rubber pieces to space it out...what else could have happened? there are no funy noises coming from the box and it just won't select the gears...
    Nov 2005
    sound like it may be the pivot on the thrust bearing under the cover at the end of the gearbox.
    Quote Originally Posted by WABIT View Post
    has come loose or its busted? the pedal is still hard to push...
    Yeah, I had one go on a MK2 once. Pulled the box and fitted a clutch before I realised.......
    I was paranoid for ages and kept a spare one in the glovebox incase I had it happen again. I could do it at the road side.
    It's under the Green VW cap.
    oh ok so its an easy job?
    whats involved?
    Nov 2005
    can you put in gear when engine is not started?
    yup and i can just drive and just match the revs and select the next gear (not using the clutch...coz its doesn't work)
    Nov 2005
    sounds like the pressure plate
