Results 1 to 10 of 11
Thread: gearbox problem, thoughts please
    Apr 2010
    prospect, SA
    just had my alignment done and the guy told me he had problems with getting it into reverse and first. when i took it there it was fine but when i left it would not go into first as if there was something blocking the gate and same with reverse. this is the first problem i've had with the gearbox without a hint before hand.
    Camden, Sydney
    Sounds like some ham fisted gorilla broke or loostened your shift linkages.
    Aug 2005
    I agree. Have had this exact same thing happen before with a rod shift linkage after I took a car in for a roadworthy and someone with an IQ of less than five points clearly had issues finding reverse gear... It turned out they had literally bent the selector rod!
    Aug 2006
    Melbourne VIC
    Seems an ocurring trend.
    Stu had a problem with some **** wrecking reverse too.
    Apr 2010
    prospect, SA
    think we got it fixed, will find out on the way to work tomorrow. changed the gear oil with full syn. plus additive and adjusted the linkage arm ( at least i think that's what it was ) seems to be working now but then again, you never know.
    Jun 2007
    Eastern Suburbs Melbourne
    most probably the linkages going south. I've always take to time explain to every mechanic abou the reverse selection, even then I still worry!
    i like volkswagens
    Jan 2010
    Baulkham Hills
    whilst on the subject of gear boxes..
    i was driving the golf all day, and i noticed every now and then, when i chucked her in first it would actually go into 3rd.. it probs happened 2 times all day (so no major issue) but what could be the problem?
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
    Aug 2009
    Quote Originally Posted by JoshFair View Post
    Inexperienced driver?
    Jan 2010
    Baulkham Hills
    HA funny. if only you knew
    Jun 2007
    probably just needs the shifter alignment to be adjusted a bit, maybe new bushes if the old ones are non existant. or just get used to it the way it is!
    i like volkswagens
