Results 1 to 10 of 16
Thread: Mk1 seat options
    Jan 2009
    south west sydney
    Mk1 seat options
    I find the seating position in my mk1 a little high. i'm not super tall or anything but i still find it a little uncomfortable to reach down to change gears. i also have a "sun visor" tint on my front window that i find i end up looking through some of the time dude to my head being so close to the top of the windscreen.
    what are the seating options? the seat rail setup in a mk1 is unusual, with only one rail at the front. is there anything that will drop in to bring the seat down a few inches. what are the guys using for rails who have fixed back seats?
    Aug 2009
    MK3's have the same tri-foot set up, i guess MK2's would too. Probably slightly different sizes. I remember a thread about it a while ago so have a search and you might find what you want.
    Sep 2009
    Chillaxing in Tas
    I noticed the SEAT Cordoba uses same setup, maybe they would fit? and look newer which is handy
    <space for rent>
    Oakleigh VIC
    MK3, MK2, Audi, Crdoba, Ibiza seats can all be made to fit by swapping the MK1 tin base and legs into the later seat.
    It's pretty simple to do and the back rest simply hooks back onto the MK1 base when you're don swapping the cushion over.
    Trouble is though all those options will leave you sitting up higher in the cabin.
    I'd probably modify a MK1 base to be a couple of inches lower and then fit that into a later seat.
    I'm 6'2" and had a lot of trouble making a race seat fit into the car low enough so my helmet wasn't rubbing on the roof.
    You should be able to get it much lower than stock with some mods.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jan 2010
    Melb Westsideeeee
    Yep, just modify your existing rails mate.
    I've done it to get my bucket seats in to fit and a bit lower. If i can find my camera i'd take a pic. Basically just chop and weld.. hehehe
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Perth. WA
    Scirocco 1 seats have the factory height adjustment, just need a miracle to find a set.
    Pete, you got those bases I sent over with the header i hope ??
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jun 2006
    Orange NSW
    Quote Originally Posted by roccodingo View Post
    Don't hurt me.. But when i put the bucket seats in my Mk1, i had a set i tossed out. A mate modified them and put them in a hilux, before tossing them in the bin.. So silly looking back now..
    Oakleigh VIC
    Yep, got those thanks
    7? MK1 Caddy
    12 Amarok
    Sep 2009
    Chillaxing in Tas
    i got some sorta nissan seats in mine.
    Height adjustment, front and rear of base. bucket type.
    Has custom mounts that where in a parts car i bought. bit of drilling and bolting and all done.
    And original mounts in tack for if i ever get done for it
    <space for rent>
    Jan 2009
    south west sydney
    how much lower can you go with that set up? the other option is to extend the shifter up and out closer to the wheel, but the throw is already pretty big and that would just make it even more noticeable. i'm thinking i'll try a bit of both. seat down an inch shifter up an inch.
    are there any short shifters available?
