Page 158 of 198 FirstFirst ... 58108148156157158159160168 ... LastLast
Results 1,571 to 1,580 of 1974
  1. #1571
    Dec 2010
    Quote Originally Posted by HiddenTaco View Post
    Do you clean out your VAG before a service? Making it look untouched.
    What I mean to say, do you reset your code changes before a service at a dealer?
    I wasn't planning on doing it for the first service.
    When I had my Golf R, I used to reflash it to the stock mapping before taking it for a service, then would flash back the aftermarket ROM after, then I got lazy and didn't bother changing it at all. Made no difference to the couple of warranty claims I made.
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
  2. #1572
    May 2018
    Hi guys,I’ve tried searching and couldn’t find anything. I’ve got a mk7.5 110tsi highline Rline wagon. Totally new to this stuff Is it possible with to turn on both DRLs like the gti or golf r?
  3. #1573
    Jul 2014
    The Hills, Sydney
    Hey Guys,
    Im probably one of the few people that like stop/start but I've found the 'expanded restart function' where the engine will restart if the car in front creeps forward even the slightest distance to be VERY annoying in traffic where people will inch forward even if the car in front of them is stationary.
    I haven't seen this mentioned on these forums but this can be turned off under ACC module > adaptions > 'expanded restart function' (potentially called 'advanced restart function') > deactivate.
    2018 Golf 7.5 110TSi Comfortline | Drivers Assistance Package | Retrofitted: Traffic Jam Assist | Emergency Assist II | Light Assist | OEM Vienna Leather Sports Seats with full Highline Interior | Power Folding Mirrors
  4. #1574
    Aug 2017
    Uk
    It’s on the obdeleven forum
  5. #1575
    Aug 2017
    Uk
    Quote Originally Posted by Rich86 View Post
    i think it’s a hardware thing with some lights, but I could be wrong
  6. #1576
    Jun 2018
    Europe
    Hi Guys
    I'm having some problems with enabling the acoustic signal (horn) confirmation when locking or unlocking my car. It is a VW Passat from Feb. 2015 (without an alarm).
    I've done the next with no result:
    In the 09-Central Elect. module, under 10-Adaptation (with security the code 31347)
    1. Acknowledgement signals-Akustische Rueckmeldung entriegeln active
    2. Acknowledgement signals-Akustische Rueckmeldung global active
    3. Acknowledgement signals-Akustische Rueckmeldung Signalhorn active
    4. Acknowledgement signals-Akustische Rueckmeldung verriegeln active
    5. Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn kurz
    6. Acknowledgement signals-Menuesteuerung akustische Rueckmeldung active
    I've also enabled enabled the "Acoustic Confirmation" in the infotainment system.
    Do you have any ideas what should I try ?
  7. #1577
    ^^^^ proton: My instructions (for a Golf mk7) for this tweak HERE.
    looks like your changes are OK - what happens and do you have any error messages?
  8. #1578
    Jun 2018
    Europe
    Hi Don,
    I did a scan for error, and there are NO errors. I also tried keeping the "Car Start/Stop" button pressed for more then 10s and still no change. I've also read a Map of the 09 - Central Elect. module (the adaptation part) and indeed the values that I've changed are set to "active" and "kurz".
    Any ideas regarding what could I try?
    P.S. the changes were done using your instructions
    Proton
  9. #1579
    Proton: hmm....... I'm very much guessing, but I am aware that the Akustische Rueckmeldung Signalhorn channel setting in my instructions can be problematic if any part of the anti-theft alarm facility is active. I think that the assumption is that if the anti-theft alarm is operating, a siren is fitted to the car (hence the Akustische Rueckmeldung Signalhorn channel setting should be not active)
    There are a bunch of adaptation channels in the BCM (@ address hex09) related to the anti theft facility - they contain the term "anti theft device" and "DWA" (it's German for DiebstahlWarnAnlage which means car-alarm).
    Just a suggestion, but have a look through your BCM admap and check is any of these channels have a setting of "active"
  10. #1580
    Jul 2014
    The Hills, Sydney
    I activated the 'free alarm' feature without the interior monitoring on my 7.5 and the coding all seemed to work although I have no idea exactly what triggers the alarm or how it works? I haven't seen much info on forums other than the coding instructions - does anyone know exactly how it works?
