Page 159 of 198 FirstFirst ... 59109149157158159160161169 ... LastLast
Results 1,581 to 1,590 of 1974
  1. #1581
    Apr 2017
    Proton: hmm....... I'm very much guessing, but I am aware that the Akustische Rueckmeldung Signalhorn channel setting in my instructions can be problematic if any part of the anti-theft alarm facility is active. I think that the assumption is that if the anti-theft alarm is operating, a siren is fitted to the car (hence the Akustische Rueckmeldung Signalhorn channel setting should be not active)
    There are a bunch of adaptation channels in the BCM (@ address hex09) related to the anti theft facility - they contain the term "anti theft device" and "DWA" (it's German for DiebstahlWarnAnlage which means car-alarm).
    Just a suggestion, but have a look through your BCM admap and check is any of these channels have a setting of "active"
    Hi Don
    Is there a way to activate the SafeLock function?
    No one can open or unlock the door from inside of the car if the car is locked.
    Thanks
  2. #1582
    Nov 2017
    NL
    Quote Originally Posted by zzc2010 View Post
    Hi Don
    Thanks
    Prefacelift = coding in 09
    Facelift = adaptions in 09
    Verstuurd vanaf mijn SM-G925F met Tapatalk
  3. #1583
    Hi Don
    Thanks
    As Rainesh correctly advises the facility is enabled/disabled by either:
    For mk7 Golf
    In BCM (@ address hex09)> Coding
    For mk7.5
    In BCM (@ address hex09) > Security Access -enter magic number, 31347 > Adaptation> ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion change to "not installed"
    BUT (and there is always a "but"), the Wiring Diagram for those mk7s that are fitted with "deadlocks" (SAFELOCK) appear to have an additional motor in the door lock unit.
    See pic below:
    So - it's unfortunately more than just a coding change
  4. #1584
    Hello community, I ask if any of you would help me to find the items to activate the automatic closing of the windows in case of rain in a Golf MK7 2013.
    I have performed the procedure of DV52 (Link: VCDS (VAG-COM) codes and programmable options for Golf Mk7) that in the first items everything is ok while as I enter Codink I can not find the entries:
    So far everything is ok.
    From here on I can not find the rumors:
    -Access control 2-Regenschliessen_ein_aus.
    -Access control 2-Regenschliessen_art
    These are my entries in Access Control 2:
    Thank You!!!
  5. #1585
    Apr 2016
    Perth, WA
    As a factory setting, VW program their vehicles that are fitted with dual LED rear lamps so that the outer and inner LED indicators flash in unison with one another (i.e. they pulse on/off together). I recently found an interesting German video (copy below) showing Dual LED rear lamps that flashed asynchronously when the turn signal was operated. Clever folk those Germans!!
    Has anyone done this (the pace car LED turn signals) on a Mk7.5 Wagon (they don't have the trailing lights like the hatches do, but two LED panels similar to the 7's)?
  6. #1586
    Jan 2012
    Me
    2015 Golf R. Lapiz Blue.
  7. #1587
    Nov 2017
    Coffs Harbour NSW
    Quote Originally Posted by The 10th Doctor View Post
    Looks like the wagon has the same tails as the pre-2019 MK7.5 GTI, which only has the indicators on the outer tailight, not inner and outer. The inner being reverse and fog.
    So not sure it would work.
    2018 Golf GTI DSG (DAP LUX INFO R-TAILS)
  8. #1588
    May 2017
    Quote Originally Posted by Rich86 View Post
    Hi guys,I’ve tried searching and couldn’t find anything. I’ve got a mk7.5 110tsi highline Rline wagon. Totally new to this stuff Is it possible with to turn on both DRLs like the gti or golf r?
    Unfortunately the R line light units do not have inner DRL or indicators like the GTi and R. You would need a set of lights from those cars to get the same function.
  9. #1589
    Albion QLD
    As others have mentioned, only the outer clusters have turn signals in them (therefore not offering another section of light to counter-flash the outer lights).
    What I want to know is if there’s a way to activate the LEDs on the boot lid cluster (that line up with the outer brake lights) to light up as brake lights (similar to those on the Mk7 LED lights), and if there’s a way for the brake light to act as a turn signal?
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
  10. #1590
    Quote Originally Posted by maca View Post
    Maca: In respect of your second question I'm almost certain that it is possible - whether it's road legal to have this US style operation of the outer brake lights is of course an entirely different question. If you can post-up an adaptation channel map from your BCM, I will have a look and make a suggestion.
