Hi zloybob,
I've been breaking my brain on this 0388 firmware wlan thing... Would it help if we compared our long coding and adaption channels to see where our differences are? I'm sure it's an easy fix.
Printable View
Chillout - great GIF!! Here's some other options that you might want to try!
http://www.vwwatercooled.com.au/foru...zXqoOpng-1.jpg
PS: Is it really that cold in the Netherlands!!
Can't get the rain closing tweak to work...went thru DV52s guide and tried everything. Just does not work. Mines a my15 R. Other tweaks have worked fine. Very frustrating. Any advice?
Hmmmm may ask my dealer next time im in then as I do now have the option visable on the MIIB screen.
Sent from my SM-G925I using Tapatalk
Let me know how you get on with that. I did the same thing, showed them the option was there (it was there from the factory, I didn't enable it myself) showed them videos of it working on other cars. They got in touch with VW Germany and were told it should be enabled or even in the menu and they removed it!
jazzyjames: Sorry to read about your difficulties. It's little solace I know, but you aren't alone in not being able to get this tweak working on a mk7.
If you still want to persevere, there are some suggestions that I can make, but I stress that these are just guesses that I have put together after chatting with a colleague in Germany (mercifully, my colleague's English is much better than my German)
Suggestion 1:Ross Tech have made many changes to their software since I wrote the tweak instructions. For example, the current VCDS software version allows the user to perform a "soft reset" of the control module on-the-fly. This facility wasn't available on the version that I used to write-up the tweak (compare the screen shots in my instructions with the picture below).
What might be worth trying is to reset the BCM after each adaptation channel change (my VCP cable does this as a standard feature). This is done by ticking the "soft reset" box (circled) then Doit! tab - see picture below.
http://www.vwwatercooled.com.au/foru...QC0Cppng-1.jpg
Suggestion 2: My understanding is that similar problems were experienced with the Skoda Octavia 3, which is also built on the same MQB platform as the mk7 and it used the same RLS/RLHS/RLFS. I'm told by my German colleague that the way that this problem was solved (for the case of the Occy 3) was to only enable Byte 0, Bit 2 (i.e. not activate Byte 0, Bit 1). On the Audi A3 (8V), again which was also built on the MQB platform and again the same RLS/RLHS/RLFS, the tweak worked by using the opposite order of Bits in Byte 0 (i.e. Enable Bit 1, not activate Bit 2)
You cold try either/both of these permutations
As I said, these suggestions are long-shots
PS: If you try these suggestions, I will include your feedback on the tweak instructions
Hello,
1. I am new here on forum, please can you tell me its this to for Passat B8 ? I trying for days to make work rain closing but not working. I have RLHS rain sensor.
2. I install folding mirrors, and i have activate in door control unit, but still not work. Its here one login code for activate folding mirrors ?
Tnx
