VCDS tweak -Increase illumination of instrument cluster clock dials
Grateful acknowledgement is given to our forum colleague ZEAL8080 for this tweak which will increase the lighting for the clock dials in the instrument cluster during daytime conditions.
The tweak works by altering the settings for the 6 x adaptation channels titled "dimming_characteristic_curve_adjustment_clock_dial _day-Y". ZEAL8080 has provided two illumination curves which I have described as "Brighter" and "More Brighter" - so depending on your preference, you may elect to use either curve, or you can make-up a curve of your choosing. The relative settings between ZEAL8080's two curves is shown in the chart below together with the default values. As the settings are increased for each of the Y set points, the illumination increases for the particular light level in the cabin at the set-point. For the "day-Y" set of channels, Y6 corresponds to the brightest illumination in the cabin, and Y1, the darkest (twighlight level).
As discussed in my VCDS tweak -Increase instrument cluster illumination during daylight instructions (see post #446), consideration should be given to allowing the clock illumination to fade sufficiently during twilight levels, so as to be a visual reminder for the driver to turn-on the headlights. This setting is for the Y1 channel in the dimming curve, so I suggest that the setting remains at hex00, or near this value.
For those attempting this tweak, a word of warning from ZEAL8080's original instructions (in the minkara forum - Japan): The BCM contains a total of 24 x adaptation channels with the term dimming_characteristic_curve_adjustment_clock_dial. It's VERY important that the correct selection of adaptation channels be made for this tweak. To avoid the risk of error, I suggest that when accessing these channels that the "search" feature be used in Adaptation channel selection screen. Enter the term "day-Y" into the search box and you should see only the pertinent adaptation channels for this tweak in the pull-down menu.
Increase illumination of instrument cluster clocks- Instructions
- Select 17 - Instrument control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 20103 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button change the settings for the adaptation channels shown in the table below (note: use the "search box" as described above)
Many thanks again to ZEAL8080 for authoring this tweak
PS: If you develop a dimming curve that is beneficial, please share your findings with other forum members
EDIT: feedback
Quote:
Originally Posted by harisg
I also implemented a smooth curve of Y daily values trying to make the illumination changes as smooth as possible.
My ammended curve falls between the default curve and the second curve by ZEAL as follows:
Y1-01
Y2-03
Y3-07
Y4-11
Y5-2A
Y6-64
These values on one hand follow the exponential form of the default curve while on the other increase the illumination to a state that is approximately the "golden mean" between the default and the ZEAL curveRegards
Feedback: Zeals curve #2 is great during bright light conditions, but my observation is that as twilight approaches, Zeal's original curve #2 doesn't allow the clock dial to sufficiently dim so as to prompt the driver to switch-on the car's headlights. To rectify this matter, I have greatly reduced the settings for Y3, Y2 and Y1 to bring them closer to the factory default values. I have also increased the values for Y5 and Y4 to brighten the clock dials as a personal preference (during overcast daylight conditions). My modified curve #2 is shown below:
DonY1 - 00
Y2 - 01
Y3 - 03
Y4 - 40
Y5 - 52
Y6 - 64
