Quote:
Originally Posted by
DV52
Janos:
Assuming Janos == jonoz? :P
Quote:
as I said in my tweak instructions, exactly the same thing happened to me. I found that I had to re-set the BCM control module to factory settings before the change would be accepted. I describe how to do this in the latter part of my post.
So you mean to run this bit?
DV52
- Press the Car button on the RHS of the discover/composition media head.
- Press Set-up on the bottom RHS of the screen
- In the Vehicle Setting screen, press the Factory Settings panel (it's at the very end of the list at the bottom of the screen)
- In the Factory Settings screen, under Reset individual settings/data, press Light
- Press Reset tab in the window that says Reset "light" settings-are you sure?
Quote:
Please don't take this the wrong way but are you absolutely sure that you have changed the correct adaptation channel? Just as a confirmation that you have followed the instructions correctly (again, I don't mean to imply that you haven't), you could check the Codinglog.txt file. If you aren't aware of how to use this file, I posted a short paper on the topic in my Mk7 VCDS Tweak - Reference thread under Reference Resouces, How To Guide.
Haha not at all mate, I work in IT and this is completely new to me to understand that the first place to generally assume is user error :D After reading through VWVortex I realised I should have been using the beta of VCDS for Mk7 changes so have upgraded to this and will perform the rest and reprogram the blink cycles.
Quote:
Failing this, you could post-up, or send me a copy of the auto-scan report for your car (an adpmap for address-09 would be even better, if you have made one), so i can see what type of BCM is in your car.
Really appreciate the offer for assistance mate, will see how I go after giving the ol' girl a clean.
