VCDS (VAG-COM) codes and programmable options for Golf Mk7
The SAD values are for the sunroof opening - I am not sure whether you have the sunroof in your vehicle??? There is actually another value you can (supposedly) adjust in the adaptions under that that allows either the tilt or full open.
It is interesting that your comfort opening is not active. Maybe it is controlling a different function apart from the radio (funk) settings?? Do your windows automatically open with just an instantaneous selection of open? I will do more research to see if I can get an answer.
It is also interesting that it is one of the few English menu items. I'm not sure why some of these things are happening, particularly when certain adaptions appear that they should be functional, when others aren't. The rain close function is a typical example of this? It is almost like the car does not always fully accept the adaptions selected, although it shows in the channels as being active or not active. Maybe the need to reset all functions in the Discover Media is more important than we think? What is further interesting is that there is a global comfort control adaption. I guess in time a lot more will be known about all this, and there will be codings that also start to make more sense.
As for the KESSY, all golf R's in Australia have the keyless access and start. I can touch the handle when closing and it will lock the doors. If I hold my hand against the handle with a window or the sunroof open it will close similar to use the key fob. What is puzzling is that although I have selected KESSY opening as active and VCDs shows this, holding my hand against the handle will only unlock the doors - it will not open the windows or sunroof. Maybe I need to recode that channel to not active, reset the discover media and the reselect it to active - this is not expected behaviour and leads me to believe something g else is going on.
Update: with KESSY opening you need to open the doors and then press on the outside of the handle. I only discovered this after translating a few international websites.... The KESSY opening function is in fact working on my golf. Apparently it is deactivated on purpose as standard as there is a slight chance that it may open the windows under certain conditions eg in a car wash or with certain other condensation events. I guess the kicker here is that you have to have the key fob close to the car for it too work as well....
I'll send you the adaption channels maps as I do them over the next week or so. I have decided to make a backup of all settings in the car for future reference, and I know that you are a strong supporter of doing this, and I can only agree with you after going through this. The Autoscan is good, but it is not good enough when you really need to find out what's going on.
Thanks for your help again.
Cheers.
