Originally Posted by
DV52
I just developed the tweak instructions below at the request of a colleague on GOLFMK7 forum (thanks Murf). Thought it might be of interest to VWWatercooled folk - so here it is:
The tweak emulates the DRL dynamic on a BMW 335i (apparently) which as Murf explains "when the car was locked or unlocked the angel eye DRL's would light up for 20 secs or so". Murf's request was made in the OBD11 thread, so my instructions are based on this diagnostic cable. Nevertheless, the instructions are easily translated into VCDS speak.
OBD11 Instructions: Front DRLs flash with lock/unlock
If the car has LED "angel-eyes" headlight fittings:
1. Select Central electrics module @ address hex09
2. Select security access
3. Enter the magic number 31347
4. Select adaptations
5. For a late-model module search for Außenlicht_Blinker. If you have an early-model module, search for Dyn. turn signal modes
6. Select Warnblinken_Zuendung_EIN change to active
7. Select Warnblinken_Zuendung_AUS change to active
8. Search for Leuchte2SL VLB10 (this is the left-side angel-eye)
9. Select Lichtfunktion G 2. ONLY IF THE VALUE IS not active, change to Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken
10. Select Dimmwert GH 2, change value to 100 (default 0)
11. Search for Leuchte3SL VRB21 (this is the right-side angel-eye)
12. Select Lichtfunktion G 3. ONLY IF THE VALUE IS not active, change to Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken
13. Select Dimmwert GH 3, change value to 100 (default 0)
If the car has incandescent headlight fittings:
1. Swap reference to Leuchte2SL VLB10 to Leuchte4TFL LB4 (note: Lichtfunktion G 2 becomes Lichtfunktion G 4 and Dimmwert GH 2 becomes Dimmwert GH 4)
2. Swap reference to Leuchte3SL VRB21 to Leuchte5 TFL RB32 (note: Lichtfunktion G 3 becomes Lichtfunktion G 5 and Dimmwert GH 3, becomes Dimmwert GH 5)
EDIT: In the first version of this tweak, it was necessary to deactivate DRL Wink (because it conflicted with the lock/unlock acknowledgement function). The instructions have subsequently been re-written to allow retention of DRL Wink in those cars that have it activated.
