Yeah It's fun. [emoji106]
Printable View
Agentthumb: Sounds like I have a new devotee for VWWatercooled's "Leuchte Programming" group (maybe even MRG_AU) !! Well done.
As you will quickly learn when you look at the 73 x permissible settings (there was 67, but I found 6 more in the latest RT software) for the alpha channels - there's lots of variations possible. The limit is entirely your imagination!!
Hi Don!
Thanks for the info. Everything has worked except for one small thing . . . and it doesn't seem to be changing! All I needed was for the parking lights values to be changed to 10 on all 4 pieces (left assemble x2 and right assembly x2)
The right side tail lights have been dimmed from value "28" down to "10". Now they were:
Outter: (10) Leuchte 21BR RC8 -Dimmwert CD21
Inner: (6) Leuchte 24SL HRA65 -Dimmwert AB24
The left side tail lights have been dimmed from value "28" down to "10". Now they were:
Outter: (10) Leuchte 23SL HLC10 -Dimmwert
Inner: (6) Leuchte 20BR LA71 -Dimmwert
The issue I'm having is all the lights have been "dimmed" to 10, from 28, except for the inner left! For some reason your table had the value at 100 for the Aus Golf R for the inner lights, so I made them 100. Then further down you mentioned to change them to "10" to balance the parking lights.
I amended this with the right side, (noticing straight away the inners were much brighter than the outers) but the left is staying at 100.
I have found the issue!!!
The value for the BRAKE light on the inner lights must be 10, not 100. When the brake peddle is depressed only the outer lights are supposed to illuminate (from factory - however - there is a tweak to make them all illuminate).
@Jazrod, it's good you brought this up. I can't figure out why the factory has set the brake lights up like this. One would think more lights when braking to alert traffic behind would be better. I have also noticed the same behaviour in other cars with 2 brake lights each side. Only the outer lights seem to increase intensity when braking.
Does any forum member know if this is an ADR requirement? Or are there other reasons?
Jazrod: Sounds like you have figured it out anyway-well done!
I know it doesn't matter now, but my illumination number for the two inner lights for (6)-Leuchte20BR LA71-Dimmwert AB 20 and for (6) Leuchte 24SL HRA65 -Dimmwert AB2 4 is correct for the Golf R (I rechecked the settings in my data base).
I suspect that your car has both the inner and outer lamps (on both sides) as stock-standard GTI set-up. That is, the settings on all four lights on your car are as shown in the extreme RHS column in my table. Since you never made any Leuchte changes to your car after you installed the Golf R fittings, why would the set-up be any different than stock standard GTI?
Hence why the value 10 is a appropriate for the illumination level on channels (6) on the inner lamp - because this lamp doesn't act as a Brake light on the GTI fitting (it just acts as a parking light). But this light does act as a Brake light on the Golf R fitting. In fact, the inner light on a Golf R acts as a brake light AND a parking Light AND as an indicator (depending on what switches are on and whether the brake pedal is depressed).
I haven't discussed here the matter of priority in the alpha channels, but there is a specified order whenever there is a conflict in a Leuchte-set. Here's an example in your project; when the brake pedal is depressed and the parking lights are switched-on how does the outer tail light decide what to do, given that it is programmed to operate as both brake and parker ? The answer is that there is a set priority level for the alpha characters - so it's quite OK to make a lamp do multiple functions. And it's also quite OK for multiple lights to perform the same function (i.e. both the inner and outer tail light on your car act as a parking light - the same function)
Here's an example of a modification of the tail lights on a NAR GTI (to a version of Golf R tail-lights) that a fellow forum colleague (JBale) managed to achieve through innovative use of Leuchte programming (note: this wouldn't be legal in Australia)
http://www.vwwatercooled.com.au/foru...8V9Fwgif-1.jpg
Of course, agentthumb's question about compliance with the ADR is an entirely different matter! I've tried to read the ADR and I have to say that its a pretty arcane document! But my rationale is that as long as the modification that is done is exactly the same as another car that has passed the ADR, then the tweak is compliant. So, for example, If I were to install Golf R taillights and I use Leuchte programming to make the new taillights operate as a Golf R, then I should be OK (I think).
The other question is: how many traffic law enforcement officers actually know the ADR to a level of accuracy that enables them to spot this type of breach - not many (if any) I would think! Though it's probably better not to get into this area of discussion if some-one is suing you after a car accident because it is claimed that your lights weren't compliant with the ADR!!
So.... Anyone in Melbourne fancy doing some VCDS treatment on my Golf 7 Highine wagon? Would love to get the rain auto close and the traffic working. Happy to pay. :-)
Thanks.
Would I be banished if I asked about VIM here?
