VCDS (VAG-COM) codes and programmable options for Golf Mk7
Quote:
Originally Posted by
DV52
Daniel: Hello. Now that's a very interesting set of "Leuchte" programming instructions indeed!! Where did you get them?
Try this:
- Restore the original values of "C5" and "C4"
- Change the following:
Adaptation channel |
Old Setting |
New Setting |
(12)-Leuchte4TFL LB4-Lichtfunktion E 4 |
not active |
Blinken Links Dunkelphase |
(15)-Leuchte4TFL LB4-Dimming Direction EF 4 |
maximize |
minimize |
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5 |
not active |
Blinken Rechts Dunkelphase |
(15)-Leuchte5 TFL RB32-Dimming Direction EF 5 |
maximize |
minimize |
Thanks for replying Don!
I've followed your table and have found that in 'dunkelphase' the drls and indicator flash in unison, so I've changed to 'hellphase' and now have the desired alternating effect. This is working irrespective of the light switch setting (auto, park lights, headlights, off).
Perfect! Exactly what I was after. Thanks!
Here's the link for where I found the instructions: [V5] ProBoards - Free Forums & Free Message Boards
Edit: here's the result https://vimeo.com/184633793
