@MRG_AU So we have the same front radar, good news :D so that part hasn't changed in order to give the new extra features of DAP2 so further my original question, perhaps we need to find some coding differences...
Possible retrofit I think yes!
Printable View
@ryanjames20 the front assist function of the car has not changed at all. The new functions are:
Blind spot monitor and;
Rear traffic alert.
Both of these use the rear parking sensors to detect cars in the rear quarters of the car.
There is also an addition of blind spot indicators in the two wing mirrors.
Maybe we need to find out if the parking modules are different between DAP1 & 2?
Despite what others may tell you, lane assist is not part of DAP2.
That's what I initially thought, but then I read some materials that seems to suggest Some BSM systems reuses the sensors used for park assist 2 (the four sensors right next to the wheels facing the side of the car), now I'm unsure.
From a cost perspective, it definitely makes sense to use what's already there, rather than adding more sensors.
Here is an example reference:
Page 2 - Blind spot detection: Car tech that watches where you can’t | ExtremeTech
From reading about blindspot monitoring, the parking sensors are mini radars in themselves and only scan about 20m unlike the front mounted radar that scans much further.
If this is the case were the parking sensors are used for blindspot monitoring in VW, then you must be able it increase the intensity of how far they work because I know my sensors only detect objects within about 2m. Another theory would be the outer sensor are a more power full type of radar. I guess this could only be eliminated by scans in VCDS and part number comparison of radars on the bumper.
The instructions below will illuminate the instrument cluster during daylight -regardless of the position of rotary light switch.
The underlying mechanism for this tweak is the mysterious (to me, at least) set of adaptation channels that contain the words dimming_characteristic_curve_adjustment. There are 35 such adaptation channels devoted to "X" values and a further 35 channels linked to "Y" values in a mk7 (but this tweak only deals with a small sub-set of "X" values).
Not much is known about these adaptation channels and I still have only a rudimentary knowledge of how they operate, but I have implemented this tweak on my own 103TSI and I can vouch that it works!
This tweak will alter the manner in which the internal photo-transistor in the instrument cluster reacts to the illumination levels in the cabin. A photo-transistor is a light sensitive device (usually encased in a transparent package) in which electrical conduction varies dependent on the intensity of light falling onto the device. In essence, the tweak establishes a new daylight response-curve for the photo-transistor that results in the instrument panel lighting-up during sunshine conditions.
For those wanting to customise the instrument panel lighting by creating their own "dimming curves", I have written a short paper on how I developed the settings for these instructions. The document can be down-loaded HERE. Also included in my paper is a link to a spreadsheet macro that I created to calculate the settings for the "X" and "Y" values for this tweak. If you want to develop your own "dimming curves" then this spreadsheet might also be useful
I have restricted these instructions to illuminating the instrument cluster during daylight hours only (by changing the "X" dimming curve) . It is possible also to modify a different "Y" dimming curve so that the dash lights also illuminate during night time darkness (with the rotary switch in the off position). However, I have not included these instructions here because of the following:
- A fellow forum member (thanks badufay) has advised that the rationale why the mk7's default settings do not light-up the instrument panel in dark conditions is to remind the driver to turn on the car's main lights. It seems prudent to retain this safety feature. As indicated in my paper, I attempted to retain this safety feature by preserving the profile (i.e. the shape of the curve) for VW's default daylight dimming curve. That is, whist changing individual "X" values, I have tried (as best as possible) to retain the relativity between successive "X" values across the entire dimming curve. This ensures that the cluster illumination will dim sufficiently at dusk to signal to the driver to turn-on the car's headlights.
- A consequence of illuminating the dash at night (with the rotary light switch in the off position) by changing the Y values is that there will be a reduced range in the adjustment facility for the cluster lighting (i.e. the "virtual slider rheostat" in the set-up menu). This impact is not insignificant, so altering the night dimming curve should be done with care!
However, if others wish to play with the "dark-side", I have included a set of values for the Y dimming curve in my paper - please refer to the link provided above.
Finally, if you do make any discoveries on this topic, please share your findings!
Instrument Cluster Illumination - Instructions
- Have the engine running and start the Ross Tech software (I found this to be necessary to successfully change the adaptation channel settings on my 103TSI - my13 model. Else I kept getting "out-of-range" error messages)
- Select 17 - Instrument control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 20103 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button change the 5 x adaptation channels shown in the table below to the New Settings as indicated: (tip: if you are using a VCDS software version that has the "search" facility - enter internal_phototransistor-X into the search box)
Notes:
- The setting for "X1" does not need to be changed - I have included it in the table for completeness
- When entering the new hexadecimal values, take care to use the exact structure shown in the table (i.e. enter all leading zeros and enter a space as shown - it is not necessary to use capital letters for the alpha characters. EDIT: agentthumb & MRG_AU (thanks both) have advised that VCDS can add an extra space at the RHS of the newly entered Hex number resulting in the message error in input please enter one hexadecimal byte eg: FF. If this happens, they suggest "clearing the entire text field and re-enter the Hex values from scratch".
- If out-of-range error messages appear, try starting the change sequence in the reverse order- that is, commence by changing X5 and then change the channels with reducing X numbers.
- EDIT: Mikey1(thanks) has advised that he did not need to have the engine running (in step 1 above) to change the adaptation channel settings on his Golf R.
- EDIT: agentthumb (thanks) indicated that the dimming curve values in the table above successfully restored cluster illumination levels following window tinting.
- EDIT: DP2K (thanks) has reported that the default settings for the phototransistor dimming curve on his/her 90TSI-MY15 Comfortline (ROW model) is different to that shown in the table above. If this is the case, I have provided an alternative set of values on post#515
Lastly, I fully anticipate that the lighting effects that result from this tweak will not be to every one's liking. If this is the case, please revert ALL settings to their default value (as shown in the table), or use my paper and the related spreadsheet to create your own dimming curves. If you do develop new dimming curves that you find to be beneficial, please share your findings on this tread
Postscript: After implementing this tweak, you may observe that the infotainment screen is brighter. If this happens, the lighting intensity of the infotainment screen can be adjusted as follows:
- Press the MENU button (thanks Mikey1) on the bottom RHS of the discover media/pro escutcheon plate
- using the RH dial on the infotainment unit (or your finger), scroll to the SETUP icon - which looks like a gear-cog and it's on the extreme RHS of the option list
- press the panel that says Screen
- press the panel that says Brightness
- Select either Brightest, Brighter, Medium, Darker, Darkest option
- Exit all screens
See Pictorial instructions below
http://www.vwwatercooled.com.au/foru.../B2RvTKc-1.jpg
I'll do this just because it's cool, and my lights dim out quite often here in Seattle because it's always cloudy. The right amount of clouds and the dash lights turn off... Gets annoying!
Ben
Ben: you will be the first person in Seattle with a daylight/night-time illuminated instrument cluster on a mk7 - can't get any cooler than that!
Seriously, your observation is exactly why I started thinking about this tweak. Given that the cluster clearly has the capacity to illuminate during these periods of cloud, I couldn't understand why VW programmed the photo-transistor in the way that it has. The only rationale that I could think-of (and that made sense) was that the car's designers intended to give the driver a warning mechanism to turn-on the head-lights in these conditions -but this is pure conjecture on my part!
Let me know (please) if you refine my tweak -and make it better!
