While I am at it here is the link to the controller map for 5F information electronics (too big for post!) any chance someone with app connect enabled could do the same so we can compare!Code:-------------------------------------------------------------------------------
Address 01: Engine (J623-CZEA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 HF HW: 04E 907 309 BJ
Component: R4 1.4l TFS H22 2326
Revision: R6H22---
Coding: 0119003223441D082000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM14TFS01104E906027HF 001004
ROD: EV_ECM14TFS01104E906027HF.rod
VCID: 6FC33DBAB624AD46B4-803A
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 61735000000178
Coding: 01FA8AA1242429750779060641CC2980512494E0608294F314205078C002
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 79D703E2F860F3F61A-802C
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120004100100011005004000101002
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 69F753A288C04376EA-803C
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AQ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0173
Serial number: 01061517400714
Coding: 03000842C24102FB0BA44080B10403281000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 0733751ABE9495061C-8052
Slave 1:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150613 042 0551
Serial number: 150621004624
Coding: 0E4DDD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y15M07D01H11M02S40
Coding: 96A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY151530JPD
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000062798780
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331518005881
Coding: 0071051001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 43ABA10ACA2C792600-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 27051503210263
Coding: 00000300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3A55DCEEBDE638EE53-806E
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR0W7H77
Coding: 98CCC000000000005C0000CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 7F23EDFAE644DDC624-802A
Seat belt tensioner; left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number: 34169677B29061571106
Coding: 333135
Seat belt tensioner; right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number: 34169676B30061510105
Coding: 333135
Crash sensor for side airbag; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 002 606 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000DDA40C41%
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 002 506 15
Component: SideSensor_Pf 001 0887
Serial number: 3586700000020749841L
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 402 306 15
Component: SideSensor_Dr 001 6149
Serial number: 35165029B1C52F3490CJ
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 6 - Part No SW: ----------- HW: 480 402 206 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502A31B5A884914B
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 15
Component: FrontSensor_D 001 6149
Serial number: 3556502C91C52F35C26O
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 26061504400352
Coding: 0C00
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 052F7F12849887166E-8050
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G1 920 940 A HW: 5G1 920 940 A
Component: KOMBI 202 6420
Coding: 27A519002780260001886A011400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 266D189E595EAC0E07-8072
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003661951
Coding: 030100043F085700FB00025C080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear.rod
VCID: 75CF0FD2D47897967E-8020
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001361390025267
Coding: 2CFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 3568387103
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 240615BFN16549
Coding: 003B0220D001048000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000006623359
Coding: 0D0000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 170615BFG06812
Coding: 003B0020DE01048000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42A5A40ED536702E0B-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000006536680
Coding: 150000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER 820 0611
Serial number:
Coding: 02730001FF00000051111101008808001F0100C601200100CF
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3041FEC66B9AF2BEED-8064
Media Player Position 1:
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4060
Serial number: VWZ6Z9R1810374
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
Serial number: --------------------
End-------------------------(Elapsed Time: 03:26)--------------------------
