Here's the process of how I ended up with the plastic tank Golf R/ S3 IC. A lot of my info comes from the internet, so it's more like a "serving suggestion" than the gospel truth.
Found info in this thread at GolfMkVNB: partnos are very important in this process.
1.8tsi comes out with the 32mm core. This is the same as the original MKV GTI & a truckload of other turbo Golfs. There is a possibility that the 32mm core on the MKV GTI was Euro & North America spec & AU & South Africa came with 38mm core - I have no idea what the flow of the plastic end tanks is.
MK6 Golf = 38mm core + plastic end tanks partno 1K0 145 803 T
pre-April 2010 S3 = 40mm core with 47mm metal end tanks. partno 1K0 145 803P. Price varies enormously from $400 - $700. About $250-$350 s/hand.
Some say the metal end tanks help with cooling, others say that because they aren't in the airflow that initially they help & when they get hot they do nothing or add to the heat. Either way, they are still a good upgrade from the 32mm core. I'm not sure those that have gone
post April 2010 S3, Golf R, Audi TT-S & others = 38.7mm core with 40mm plastic end tanks. Partno 1K0145803BE or 1K0145803BP (or 1K0 145 803 AK Audi TT-S). Price new from $195 through to $350ish. 2nd hand - I've seen them offered anywhere from $80 - $250. I paid what I thought was a fair price & the seller bent over backwards to get it delivered to me from 200km away. So I'm a happy camper.
Supposed advantages over the S3 IC:
And it looks dead stock.4 more bars spaced more closely together
* More equivalent frontal surface area, as well as internal cross sectional area - improved flow capacity
The plate design inside the bars are more closely packed
* Improved efficiency due to greater rate of heat transfer
Smoother flowing end tank ports
* Improved flow characteristics compared to the S3 fittings which have steps in diameter causing turbulence.
From what I can see, there isn't much advantages going from GolfR plastic to S3 metal tank or vice-versa. One might be better than the other but thgere wouldn't be much in it. If you have an S3 or a Golf R then the logical upgrade path will be a quality aftermarket IC.
For me with my 32mm IC the 38mm plastic tank IC is a logical & definate upgrade is it's ~20% bigger.
Mk V GTI intercooler - 1K0 145 803 S (TFSI & TSI all markets)
Mk VI GTI intercooler - 1K0 145 803 S (US) 1K0 145 803 AK (ROW - 210hp)
Mk VI R intercooler - 1K0 145 803 AK (ROW)
Audi S3 intercooler - prior to MY 2010 1K0 145 803 P, MY 2010 built before 4/19/2010 1K0 145 803 AK, after 4/19/2010 1K0 145 803 BE
Audi TT-S intercooler - prior to MY 2010 1K0 145 803 P, MY2010-11 1K0 145 803 AK, MY 2012 1K0 145 803 BE
