Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 95
Thread: Intercooler change DIY
  1. #31
    Erskineville, NSW
    Quote Originally Posted by Martin View Post
    You know you have expel and regas the aircon to install the intercooler?
    No, not required.
    Lift the front up high, remove the bumper, lights & undertray. Remove the IC hoses. Remove or loosen the front crash bar. Undo the bolts that sandwich the IC in-between the radiator & the AC condensor. Carefully slip the IC downwards out of the sandwich.
    Reverse to assemble.
    I hope that's how it works
  2. #32
    Dec 2012
    Sutherland Shire, Sydney
    It may be due to the larger size of the APR unit?
  3. #33
    Erskineville, NSW
    could be..
  4. #34
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by zei20t View Post
    I got a set of them from ebay also
    quite easy to fit, a hoist makes it 1000000000 times easier.
    the right-hand pipe with the sensor flange didn't fit the sensor for me. the thread is wrong for the factory bolts. so buy some beforehand that fit in the holes.
    I bought the same kit as well and had the above problem. The sensor flange also was pointing the wrong direction so a hose hit it, meaning that after finding bolts that worked, I couldn't mount it in the right direction. I ended up zip-tying it on which has worked. Theres a little gap under the plastic of the sensor, but its double o-ringed, should be fine.
    Not only that but I found that it was overall long enough at the bottom, so I had to reallllllly stretch the passenger side hose to make it reach. And then the metal drivers side one in that kit didn't fit at all, seemed completely different in length and its mounting points didnt reach out... Funny, as you have an Octy as well???
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  5. #35
    Jul 2013
    Caulfield, VIC
    I just had a thought- I was going to get the twintercooler ebay version as even though I can see more potential/less lag from the one Lucas got, half the reason Im buying it, is so it looks tough That one doesnt really poke out near the front at all... I have HEAPS of space, at least 6 or 7 cm before I have to cut anything.
    I wonder if THIS UNIT could be mounted with long bolts and spacers and longer tubing to make it fill the gap more? The idea is it looks good enough so that I can remove the horizontal slats from my grill which look poo, saving me money on a honeycomb grill.
    My RS build thread
  6. #36
    Jan 2012
    oh. well, hi there!
    Intercooler change DIY-wp_20140122_17_12_19_pro-jpg
  7. #37
    Jul 2013
    Caulfield, VIC
    oh. well, hi there!
    I think I'm going to have to give in on the looks department, and gst this one for pretty much guaranteed non lag vs twintercooler...
    Looking in do the fins line up with each other for better flow speed?
    Also, link to item id please
    Sent from my HTC One X using Tapatalk
    My RS build thread
  8. #38
    Jan 2012
    I have no idea. its sitting on the floor in my garage.
    I wanted to keep my car stock looking, which is why I don't have a 4m truck core sitting in front of my bumper. IMO the twintercooler is a pretty poor setup. 2 cores don't equal better cooling or better flow. Essentially you have increased your volume by 2.
    Anyway, this SHOULD be a bolt-in installation. might attempt it this weekend, I think I have the time.........
    VW Golf GTI 06 10 2 0T Turbo MK5 Fmic Intercooler KIT Version 2 RED | eBay
  9. #39
    Jul 2010
    very nice.
    u going to install it urself?
    let us know how it all goes.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  10. #40
    Jul 2013
    Caulfield, VIC
    Sweet. That's the same one Lucas got and it's bolt on. He also knows a few lads who have had success with those for the price they are
    My RS build thread
