Page 1 of 10 123 ... LastLast
Results 1 to 10 of 95
Thread: Intercooler change DIY
    Erskineville, NSW
    Can anyone point me in the right direction for an intercooler change DIY for an Octy2?
    thx
    Jan 2012
    AUDI S3 core?
    bolts straight in AFAIK.
    if not, make sure you get a kit that has ALL parts required. youll need to remove the front bar at the very least. not a big job.
    And if its anything like my Golf (which it probably is), remove the plastic tray under the engine, the front bumper, then headlights, then the crash bar, then the large plastic surround that houses radiator/intercooler etc. Then unbolt your a/c radiator from the front of the intercooler and also the bolts that secure the intercooler to the radiator behind it (all 3 radiators are joined together with bolts). Then disconnect the rubber hoses and it should be ready to remove.
    Fit the new intercooler, fit the new hoses (make sure the green rubber seal on the drivers side hose is seated correctly to avoid leaks) and then reverse the above steps to put everything back together. Took me about 4 hours, and that included taking my time and taking pics along the way for reference.
    When removing your bumper, make sure to put some sheets/towels under the front of the car to avoid scratching the bumper on your garage floor when it comes off.
    Dec 2012
    Sutherland Shire, Sydney
    It may be due to the larger size of the APR unit?
    Erskineville, NSW
    S3/golfR plastic tank version - an extra 7mm of core but it looks totally OEM. It's as good / possibly slightly better than the metal tank S3 unit if threads over at GolfMK6 are any indication.
    I know it bolts straight in - except for possibly an issue with the alignment tabs in the connector.
    My biggest issue is streamling the removal of the front end components so that I'm not removing parts unnecesarily.
    I have a Golf MkV DIY from the forge motorsport site but was hoping for something slightly more targetted
    Not a DIY, but here is a pictorial that i did when i replaced my intercooler. Some of it might be helpful. There is a link to a GTI install guide which might be handy for you.
    THS Copy Intercooler review and installation pictorial semi-DIY
    Front bumper removal DIY (MK6 GTi): MK6 Front Bumper Removal
    Intercooler instructions for MK5: https://docs.google.com/file/d/0B7H1...U2c/edit?pli=1
    EDIT: Another DIY here which might be handy (MK5): http://www.golfmkv.com/forums/showthread.php?t=168162
    Erskineville, NSW
    Thanks Lucas
    You must have an excess of good karma around you if your helpfulness is any indication.
    Bowral, NSW
    Whats the bet that the S3 radiator will fit a TDI?...
    *And work well
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Thanks Lucas
    **blushes**
    Happy to help anyone if i can. Mind you, after immobilising my own car last week due to not plugging the dash cluster back in correctly, im not sure i should be giving advice to anybody
    Re karma, i actually have terrible luck, so im not sure i believe in it unfortunately.
    Erskineville, NSW
    Eventually, things all come together.
