Results 1 to 10 of 14
Thread: VAG-COM Error codes from my car ...
    Apr 2010
    Sydney,NSW
    VAG-COM is showing me the following errors:
    Address 01: Engine Labels: None
    Part No: 066 906 032 AJ
    Component: MOTRONIC ME7.1 G 0002
    Coding: 00031
    3 Faults Found:
    17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
    P1296 - 35-10 - - - Intermittent
    16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
    P0139 - 35-10 - - - Intermittent
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 35-10 - - - Intermittent
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B2 907 044 C
    Component: CLIMATRONIC C 2.0.0
    Coding: 110001
    Fault Found:
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    37-10 - Faulty - Intermittent
    The first and second are self explanatory, is the third one the MAF? And what is this footwell/defroster flap positioning motor? Is it hard/expensive to fix?
    Thanks!
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Aug 2007
    Five Dock, Sydney
    Hi Adam, I beleive its the same as the recirculation flapper, and its under the dash in the passenger footwell. I had this error once, cleared it and it's never come back. BUT there is a distinct servo-clicking sound occasionally but you can temporarily reset it by turning on the AC and selecting Recirc. BTW it a real PITA to fix by previous accounts.
    Other than that, looks like the VAGCOM cable did the trick for troubleshooting... not sure about that Secondary Air Injection System: Incorrect Flow Detected error
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by goodfella View Post
    Ah! I could hear a clicking sound from the centre of the dash, thought it was something to do with having the cable attached. Will try resetting the code and see if it comes back.
    I wonder if that Secondary Air Injection System error could be because of the split vacuum hose?
    Adam
    Previously -
    2002 Bora V5
    Go to the ross-tech.com wiki and look up the codes. Or google them. Usually worth deleting and checking what comes back.
    Apr 2010
    Sydney,NSW
    Good call Gavin! Found the secondary air injection one on the wiki here: 16795/P0411/001041 - Ross-Tech Wiki
    All sounds quite vague though, quite a few things it could be. One of them is pipes/hoses between components so maybe, just maybe, it is being caused by the split vacuum hose I found (see other thread). Will get that replaced first, reset the codes and see how it goes.
    Adam
    Previously -
    2002 Bora V5
    That's the problem when there's more than one thing that could set off the code. You just have to use your imagination a bit and think outside the box.
    Boost leaks for example, usually snag the diverter valve, not very often a problem cos most folk have replaced them. It's just the only thing the ECU has control over that could be causing the leak.
    Apr 2010
    Sydney,NSW
    OK, so 5 days after changing the breather hose (aka vacuum hose) the only fault showing on the VAG-COM now is:
    1 Fault Found:
    P0139 - 35-00 - -
    Definnitely need to get that replaced then. Not sure how the breather hose has fixed the coolant sensor but hey, VW's work in mysterious ways right?!
    Adam
    Previously -
    2002 Bora V5
    Coolant sensor code could be from 5 years ago and hasn't been cleared since being fixed?
    Apr 2010
    Sydney,NSW
    Like your thinking Gavin but a dealer reset the codes a few weeks ago after seeing faults from the MAF, O2 and Coolant sensors, so the coolant sensor fault I saw on the VAG-COM (in my OP) occurred after that reset.
    I have ordered a new O2 sensor from ECS today and while I was at it ordered a coolant sensor too as they are not expensive, might as well change it at the same time and know I have a good one in there.
    Adam
    Previously -
    2002 Bora V5
    Apr 2008
    Did you order the coolant sensor clip with the sensor itself?
    You should be getting the green coloured coolant sensor (the black one is now considered obsolete).
    Nothing to see here...
