Results 1 to 10 of 14
Thread: VAG-COM Error codes from my car ...
    Apr 2010
    Sydney,NSW
    Quote Originally Posted by goodfella View Post
    Hi Adam, I beleive its the same as the recirculation flapper, and its under the dash in the passenger footwell. I had this error once, cleared it and it's never come back. BUT there is a distinct servo-clicking sound occasionally but you can temporarily reset it by turning on the AC and selecting Recirc. BTW it a real PITA to fix by previous accounts.
    Other than that, looks like the VAGCOM cable did the trick for troubleshooting... not sure about that Secondary Air Injection System: Incorrect Flow Detected error
    Ah! I could hear a clicking sound from the centre of the dash, thought it was something to do with having the cable attached. Will try resetting the code and see if it comes back.
    I wonder if that Secondary Air Injection System error could be because of the split vacuum hose?
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Go to the ross-tech.com wiki and look up the codes. Or google them. Usually worth deleting and checking what comes back.
    Apr 2010
    Sydney,NSW
    Good call Gavin! Found the secondary air injection one on the wiki here: 16795/P0411/001041 - Ross-Tech Wiki
    All sounds quite vague though, quite a few things it could be. One of them is pipes/hoses between components so maybe, just maybe, it is being caused by the split vacuum hose I found (see other thread). Will get that replaced first, reset the codes and see how it goes.
    Adam
    Previously -
    2002 Bora V5
    That's the problem when there's more than one thing that could set off the code. You just have to use your imagination a bit and think outside the box.
    Boost leaks for example, usually snag the diverter valve, not very often a problem cos most folk have replaced them. It's just the only thing the ECU has control over that could be causing the leak.
    Apr 2010
    Sydney,NSW
    OK, so 5 days after changing the breather hose (aka vacuum hose) the only fault showing on the VAG-COM now is:
    1 Fault Found:
    16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
    P0139 - 35-00 - -
    Definnitely need to get that replaced then. Not sure how the breather hose has fixed the coolant sensor but hey, VW's work in mysterious ways right?!
    Adam
    Previously -
    2002 Bora V5
    Coolant sensor code could be from 5 years ago and hasn't been cleared since being fixed?
    Apr 2010
    Sydney,NSW
    Like your thinking Gavin but a dealer reset the codes a few weeks ago after seeing faults from the MAF, O2 and Coolant sensors, so the coolant sensor fault I saw on the VAG-COM (in my OP) occurred after that reset.
    I have ordered a new O2 sensor from ECS today and while I was at it ordered a coolant sensor too as they are not expensive, might as well change it at the same time and know I have a good one in there.
    Adam
    Previously -
    2002 Bora V5
