Also try wastegate acutuator, make sure it isnt getting stuck, and a whole bunch of hoses... good luck
Hey guys still ongoing saga.. Still intermittently won't spool. Checked visible vac hoses on top, nothing broken. Swapped DV back to oem. No improvement.
Fitted boost gauge, when she's not working she just sits on 5psi and can quite clearly hear that the turbo isn't spooling.
What could cause the waste gate to get stuck? What should I look for under the car?
Sounds like the WG flap may be permanently open or has no preload. You can just see the actuator from the top of the back of the engine. Have a look to see if it still has two nuts connected to either side of the rod first off.
I'll have a look when i get home. But the thing is when the engine is cold, or driven from cold it spools fine. Its only once you've stopped the car for a few minutes (even sometimes in traffic) that the stupid turbo then stops spooling for a while, then comes back good.
If the WG flap was permanently open it wouldnt ever spool would it?
Also should mention, when the car is cold and i drive past vehicles on the drivers side as the turbo spools, it makes a clicking noise that gets faster with revs (sounds like sticky lifters) but a sharper, louder sound.
9n3 Polo GTI - | GIAC | APR R1 DV | RDA slotted rotors | Remsa pads | Whiteline bushes | 17x7.5" RS6 reps | Optima yellow top | Clarion / Audison / AVI / peerless audio
Sorry my bad, I though you could never get it to spool so it's probably not the actuator. But that ticking noise is a worry. I say get it someone soon for a professional opinion.
To me it sounds like (and dont hold me to it) like its either the n75 internals flapping around and vibrating as the ecu tries to regulate the boost, or its the actuator on the turbo, rattling around to the tune of the n75 directions. The N75 is ontop of the heads though, right?
Any tips on how to test the valve and see if its kaput?
Yep the back of the engine and coming off the bend on the TIP.
You can just disconnect the plug and go for a run and see if there is any noise I guess.
I thought the n75 was under the plastic engine cover? Or is that another 3 way vacuum solenoid of sorts?
Should be directly off your turbo inlet pipe, between the PCV and DV. I think it's the N249 or N112 your referring to, sorry can't remember exactly.
