Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: Polo GTI, Rear Toe Out Shim Ajusters.
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Well then can anyone find out any data on these (whiteline wouldn't) just the thickness from one end to the other will do for now. So I can muck about with getting some made & after what Neil has mentioned may be not as savage. I will also look at getting extras made.
    P.S. Me want.
    Hooroo.
    Jan 2009
    Eddy, would you mind elaborating on the rear tyre wear, as in how bad?? Is your suspension stock? Is it a result of mods?
    Or PM if it's too far off topic. I'm tracking mine this weekend, it's all stock atm, but got H&R springs awaiting my pick-up
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Well my suspension is changed & on the track the rubber just peeled off the rears while the front was ok & this after dropping the pressures several times, can't say any thing about standard set up, haven't been there.
    You might find that your set up will be ok as is.
    P.S. Me also a fussy bugger.
    Hooroo.
    Mar 2007
    Gold Coast
    Hi Eddy,
    If you can work out the width of the plate (maybe measure the spacing of the bolts), then compare this with the diameter of the wheel, you can work out how much toe-out you will get by varying the thickness of the plate..
    E.g. of the plate is 100m wide, and the wheel 600, if the plate is 1mm thicker at the front, you'll get 3mm toe-out (assuming you start with 3mm toe-in).
    I reckon you should get a few sets of plates with different thicknesses made up at the same time. Maybe you could also vary the thickness top to bottom to change the camber? (assuming you felt the need to do so).
    Feel free to correct my maths if I've gone awry.
    Cheers,
    -Phil.
    Sep 2006
    Tweed Heads
    Quote Originally Posted by philthy View Post
    Hi Eddy,
    Cheers,
    -Phil.
    Hoyhoy.
    I'll keep this in my mind, Ta, Phil.
    Hooroo.
    Feb 2007
    Brisvegas
    My Whiteline shims should arrive Monday if you want a look Eddy???
    Sep 2006
    Tweed Heads
    Quote Originally Posted by VWindahouse View Post
    Hoyhoy.
    What, where from, don't go & tell me Whiteline, hey.
    Hooroo.
    Feb 2007
    Brisvegas
    Through a reseller actually.... Do you want me to order you some
    Sep 2006
    Brisvegas
    You never told me this.
    Dam you
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Feb 2007
    Brisvegas
    Ha ha sorry mate I only ordered them two days ago, my bad
