Ones with Forge turbo inlet pipe
Hi guys, had a question for you all.
I got my TIP installed (by a mechanic), and back of the engine between the firewall, there is a thin piece of metal that runs all along the back. The sharp corner end of it seems to be rubbing against the TIP. I am guessing over time with movement, this could potentially damage the TIP and create a leak.
Can I bend this metal piece? I don't know why it's there... do others install also seems to be right against it? If you look down using a torque on the back, you should be able to see....
Thanks..
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
