Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: intake setups
  1. #21
    Mar 2009
    Sydney {GO BLUES}
    if u want unrestricted air wouldn't you get a cold air induction with pod
  2. #22
    Nov 2008
    Maybe he wants it to look stealth ?
  3. #23
    Dec 2006
    Gold Coast
    I did once mount a pod inside the standard airbox. That was about as useless as it gets.
  4. #24
    S.E Melbourne
    wasn't the whole debat that taking out the air box and replacing it with a pod filter was good for all of two seconds before the heat soak killed it?
    way around it was smaller battery and routing your intake from behind the left fog light?
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
  5. #25
    Jan 2009
    WEst Sydney
    Quote Originally Posted by DeanB View Post
    I think he means this ...
    so the extra pipe would be on the "unfiltered" (bottom) of the air box.
    Don't know if it is at all feasible or if there is any point to it as you'd need an idea of whether the SEAT intake alone is a restriction. From things I've read on here before, it's always been open to debate. I've seen on some of the OS forums where they've just used a hole saw and drilled more holes in the box.
    But if you drill the airbox it will draw hot underbonnet air. But the stock air feed (replaced by the seat intake) works a treat as a secondary intake under the airbox. Pulls air from underneath the car. I dont think you will get nasties going up through there. It would be like shooting a basketball from 300 metres and getting it swish in the basket.
  6. #26
    Apr 2008
    Perth
    Quote Originally Posted by Whubbsie View Post
    a FMIC would fix this wouldnt it? i mean aslong as the charge is cooled as much as possible after the turbo what difference would hot air going into the turbo be as cold air from a cold air induction would just be heated by the turbo?
  7. #27
    S.E Melbourne
    no idea... but you'ld get that result with or without the the pod filter.
    just the pod filter has been discussed before and the last time it come out that pod filter inplace of your airbox made no gain and was just a waste of money... I'd back that up but way to lazy to go find the old threads
  8. #28
    Feb 2007
    Brisvegas
    Pod filter does buy you spool sound points for the $$$'s
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
  9. #29
    Jan 2009
    blankedy
    Quote Originally Posted by Petrina Polo View Post
    I think the ultimate question is: Is the Seat intake with box still too restrictive? If not, why bother modifying?
    I wouldn't be worried about stones, etc, but under the car there is a lot more water and dust than on the front grill (normal inlet position).
  10. #30
    Jan 2009
    Bucharest, Romania
    did the "seat PD160 intake" mod yesterday, and made some vag-com logging.
    here's a before(1)/after(2) chart:
