Hi, I would need some expert advise here. My ICE setup is in my signature. I have Fiscon plus (v1.83 software) and MFA on my RNS510 (firmware 266
My Fiscon BT works like a charm when it's connected up with the amps and stuff, without the Alpine PXA-H701 processor. But once I plug in the H701, the caller will hear very clear echo of his or her own voice when I answer the call. They sound like they are talking to themselves, hearing repeats of every word they say.
After some trial and error, I found that the caller is actually hearing himself through the mic when his voice is re-produced via the car speakers. When I turn down the speaker volume, the echoing starts to disappear....but then I can hardly hear the caller too. Somehow, the H701 is delaying the voice signals by a sec or so such that by the time the voice is projected out of the speaker, the mic is already in receving mode and picks it up...
I've tried moving the mic from the front cabin light area to the top of the A pillar....doesn't help.
I've tried disabling the time alignment feature in H701....doesn't help.
I've tried putting 2 layers of sponge over the mic....doesn't help.
I've tried plugging in another different unit of H701...doesn't help.
I've tried removing the H701 and plug the RCA inputs directly to the amp....no more echo, works like a charm.
The last thing I've not tried is VAG-COM programming but someone told me that it will throw up a series of fault codes as I'm not using the original VW BT module. Not sure how true this is.
Basically I'm looking at:
Telephone - Contoller 77
Channel 130 (offset delay to avoid echos)
or Channel 136 (ofset delay for send & receive)
I can't find any functions in Fiscon Plus that can set any delays as well..
Can any experts advise?
