Results 1 to 10 of 16
Thread: DAB+ versions of RNS510 now available
Threaded View
Ryan_R DAB+ versions of RNS510 now... 26-12-2013, 09:23 PM
hoi polloi At €1600.00 though it's a... 26-12-2013, 09:37 PM
sVWatt Ouch. Bit x$y for now. What... 27-12-2013, 07:38 PM
robbie I read that only these units... 29-01-2014, 05:50 PM
hoi polloi No, but £799 beats €1600 -... 29-01-2014, 08:02 PM
saint70 Rns-510 and dab+ 15-02-2014, 06:16 PM
saint70 Forgot to tell: on info of... 15-02-2014, 06:21 PM
Guest001 Dab+ is not available on ... 15-02-2014, 09:51 PM
saint70 Thank you for answer :) ... 15-02-2014, 10:07 PM
booba you need a new hw revision... 06-04-2015, 10:48 AM
YellowLemon I got the RNS510 DAB+ and it... 22-04-2015, 06:54 PM
dero Opinions about retrofitting... 25-06-2015, 02:58 PM
saint70 That strange since i have... 04-01-2016, 08:07 PM
Ryan_R Updated original post with a... 04-01-2016, 05:08 PM
Ryan_R That's RDS (Radio Text) which... 04-01-2016, 08:20 PM
saint70 No, i am not going spent... 04-01-2016, 08:31 PM
    Apr 2010
    Was searching for something else to help someone and then figured I'd check if any progress had been made on getting digital radio for our RNS510's, and it looks like we're in luck.
    Only bad news is that the system needs replacing with a new version that has the black digital antenna connection (up top). I did hear others talk about some other DAB+ adapter that uses the MDI wiring (so the MDI would stop working if you had it) but I haven't seen where the actual product is.
    Adding DAB/DAB+ support to the Volkswagen Golf Mark V & VI, Jetta, Passat and others | my-gti.com
    RNS510 Teilenummer C mit DAB+ • Golf VI GTI Community • Forum
    Anyone game? I think I can survive without it until I replace the car, plus I'm happy to stream those stations via Internet bluetooth connection. If two-way Android mirroring was also there as a feature I'd be a lot more tempted to upgrade (could then get Google Maps on the RNS).
    In other news you can also now get the steering wheel module for the Mk6 Golf reversing camera that shows the moving guidelines. Part number 5N0907441.
    [+] UPDATE 4 JAN 2016
    To help new visitors work out which unit they wish to buy, note the following:
    Part Numbers:
    xxx xxx 680 – Europe / Australia / Russia / Africa
    xxx xxx 681 – Japan
    xxx xxx 682 – China
    xxx xxx 684 – USA / Canada / Mexico
    xxx xxx 686 – DAB/DAB+
    At present, the following DAB+ models are available:
    1T0 035 686 G (1T0035686G) – RNS 510 DAB/DAB+
    1T0 035 686 E (1T0035686E) – RNS 510 DAB/DAB+, EU West V10 Maps
    1T0 035 686 F (1T0035686F) – RNS 510 DAB/DAB+, EU East V10 Maps
    These units also feature:
    New GPS chip
    40GB SSD Hard Drive
    Thanks to my-gti.com for this updated info!
