Page 9 of 24 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 239
Thread: BlueTooth related questions (all BT questions go in this thread only)
  1. #81
    Oct 2012
    Melbourne, Victoria
    Quote Originally Posted by readerr0r View Post
    The plug on the unit will be the same, so you should be able to do a straight swap of the black boxes (if it is indeed a 9W2 and not some parrot jobby). But you may need to do some VCDS coding on the new 9W7.
    Alright, fantastic. I was concerned that I'd have to start pulling apart more than just the centre facia to run new wiring.
    Much appreciated.
    Biscay Blue Volkswagen R36 MY09
  2. #82
    Feb 2013
    Blue tooth
    Hey guys, just a quick question, I am having issues with the bluetooth and im not sure if its normal (vw thinks it is...)
    if i am listening to radio or a cd with my iphone bluetoothed to the car and a message/push notification/someone unlocks my phone, the head unit automatically switches to bluetooth music. How do I stop it as it drives me up the wall.
    Jan 2011
    I would try another VW dealer.
    My iPhone is constantly connected via Bluetooth, if that happened every time my phone tried to make noise, I would have sold the car by now.
  4. #84
    You need to disable BT autoplay.
    Can't remember where it is in the menu, go to setup and then media I think...
  5. #85
    Jan 2011
    Brisbane - QLD
    Quick question to those who have retrofitted a 9w7 bluetooth kit (mated to RNS510).
    Did you need to unplug the main connector behind the RNS510 to fit the bluetooth wiring?
    If yes, did you need to re-enter the security code to activate the RNS510?
    I have one arriving this week and will be installing it probably this weekend in my Tiguan if it does not need the security code . Otherwise I have to get the code first from VW service
    MINI Cooper S Clubman - FWD
  6. #86
    Aug 2011
    Quote Originally Posted by nat225 View Post
    Q1 - Yes
    Q2 - No, if your RNS510 came with the car from factory. Yes, If it was from ebay, audiupgrades, dealer etc.
  7. #87
    Jan 2011
    Brisbane - QLD
    Q1 - Yes
    Thx!
    Just clarifying Q2.. bought the Tiguan used fr a Skoda dealer and it already has the RNS510 & RVC. BUT, can't really tell if it was factory optioned or dealer fitted one.. it has a RCD510 manual too
    The GPS antenna is on left corner the dashboard instead of a sharkfin one. It's a prefacelift MY2011 model. Perhaps someone with a prefacelift RNS510 optioned Tiguan can confirm if it should have a sharkfin one if from factory?
  8. #88
    Apr 2010
    You only need the code if you connect the RNS510 into a different car. I've disconnected my one (from eBay) plenty of times, have also had battery disconnected a few times, I only needed the code the first time I retrofitted it.
  9. #89
    Aug 2011
    Thx!
    The GPS antenna would never be on the dash if it was done at factory, that's for sure!
  10. #90
    Jul 2010
    Spot on!
    MY11 Tiguan 147TSI (SOLD)
