Results 1 to 2 of 2
Thread: Intermittent Wiper Function
    sydney
    Have a 2009 Passat CC with RLS ( rain light sensor ) module.
    Is it possible to use the intermittent function on the wiper stalk and by bypassing the RLS sensor G397.
    Since I had a windscreen replacement , non vw , the intermittent / rain sensing wiper does not work correctly.
    I have replaced the RLS sensor and silicon pad.
    Wipers will activate if I step down from high sensitivity to low sensitivity on the wiper stalk.
    Wiper speed only works on continuous slow or high speed.
    Wipers will stop when the car is stationary and start wiping when the vehicle is moving .
    However if I have the sunroof and windows open the auto close the rain closing feature activates when I spray the RLS with a hose.
    Auto headlight turn on is functionally as per norm.
    The RLS unit is only a 3 wire module so I assume 2 are for power and the third is for the databus
    VAGCOM error log indicating sporadic / no signal communication on RLS G397
    sporadic / no signal communication on Control Module J519
    Any hints on where is J519 module and wiring pinout for the RLS module.
    Mornington Peninsula, VIC
    Is your glass OEM? Different colour glass needs to be coded in the RLS.
    Does the sporadic coms error go away if cleared?
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
