Need help with 9W7 Bluetooth with RCD510 on gti mk6
Hi Guy,
I have a vw golf gti mk6 and i believe my bluetooth was 9w2 and i tried to change it to a 9w7 but it doesnt seem to be working.
it comes up on the radio and the MFD but it keeps trying to connect to previous owners phone and i am unable to get it to display in the bluetooth section on the mobile to connect to. so basically it wont show up on my mobile and i cant search for the phone to connect to. i try my mates 9w7 module in my car and it connects up straight away so i dont know what the problem is. could it be coding? can some one help.
this is my auto scan.
Chassis Type: 1K (7N0)
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 1010
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 48180ABAE837F1C0408800803400092441550088737D8D6064 8000200040
Shop #: WSC 01357 011 00200
VCID: 3851FA728B72A4E196F-806D
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 29091 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 011010 05 54 0403
Coding: 0330AD
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
No fault code found.
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RAEJH2R
Coding: 00003956
Shop #: WSC 30020 959 100527
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 3147C756600875A9D11-8064
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME26627258ZZZV
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7D693158ZZZ3
Crash sensor for side airbag; rear; driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME1A137173ZZZO
Crash sensor for side airbag; rear; passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME3A24701AZZZT
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JID000MA
Coding: 1892140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76CD344AC9E61291443-8023
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0136652
Coding: 830000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H20 0420
Serial number: 00000000000000
Coding: 170F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 71C70756A08835A9911-8024
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 031010F2001919
Coding: ED817F0600060200000003
Shop #: WSC 50620 822 175810
VCID: 6DFF1B2674B0D149B59-8038
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 59
Reset counter: 180
Mileage: 72323 km
Time Indication: 0
Date: 2015.07.19
Time: 18:03:28
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AF5103A8D5EC671D0B-803F
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0000692
VCID: 3147C756A80875A9D11-8064
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0000692
VCID: 3245C85AAD0E4EB1A8B-8067
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1443164
VCID: 3449CE42571A4081BA7-8061
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 041 0167
Revision: 00000001 Serial number: VWZ1Z3K3569519
Coding: 0500044004
VCID: 62E5781A7D6E9E3118B-8037
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 58
Reset counter: 180
Mileage: 72323 km
Time Indication: 0
Date: 2015.07.19
Time: 18:05:12
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 354FF3465C6059898D9-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 364DF44A41665291843-8063
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668647795
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
1 Fault Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 132
Mileage: 72323 km
Date: 2015.07.19
Time: 18:06:43
- You may not post replies
- You may not edit your posts
Forum Rules
