Results 21 to 30 of 37
Thread: problem worthy of lols...
  1. #21
    Jun 2006
    Orange NSW
    The bit that i don't understand is you are saying it's so easy, then you are saying you can't figure out what is wrong with your car?
    When i'm stuck on something i don't know much about, i ask someone in the industry. That usually follows with me paying them an agreed fee and them fixing it for me.
    But hey, i'm no expert either.
  2. #22
    Jun 2006
    Orange NSW
    Start the engine and spray aerostart around the manifold. If your RPM rises, you have a vacuum leak somewhere. That's fairly easy to determine.
  3. #23
    Jul 2007
    Launceston
    There you go! I just learnt something too
    I'm going to the pub... I may be some time...
  4. #24
    Jan 2008
    Newcastle, NSW
    Hope it sorts out Mick, unfortunately I don't have anything constructive to add to this thread though!
  5. #25
    Dec 2007
    Ermington, Sydney
    What's so hard to figure out? I installed a new manifold, which wasn't physically hard for me to change as I know how to unbolt and bolt a manifold onto my vr6 engine. Like I previously said - the problem I have is with stalling, and I don't know why it's happening or what it has or has not got to do with my new manifold, which is why I asked about the problem on here.
    The manifold came bolted together with things like the throttle body, ISV, vacuum lines, intake temp sensor...all these things might be causing a problem but I don't know, hence why I asked if anyone else did.
  6. #26
    Point Cook, Vic
    perhaps you should start by swapping your old tb, ISV etc back on.
    See if it still does it.
    FOLLOW US ON FACEBOOK
  7. #27
    Jul 2005
    Newcastle, NSW
    Are you sure the manifold is correctly mated?
  8. #28
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by Tim View Post
    Yeah that was my next plan of action - which I just came back from doing, with no luck unfortunately.
    Quote Originally Posted by mikinoz View Post
    Yeah, all surfaces down properly, gasket in, bolts done up, etc. Checked all that whilst fitting it because it was very tricky to align it in the first place.
    Funny piece of news...I decided to unplug the MAF for the sake of it, and the car didn't stall. When the MAF is plugged in, the car drops to idle faster, idles lower, idle is unsteady and it stalls. When the MAF is unplugged, it drops to idle slower, idles at around 1000rpm or just under (at least until about 6 or 8 seconds have gone by), doesn't stall and isn't unsteady.
  9. #29
    Feb 2008
    mOOROOLBARK
    what is aerostart and where do you buy it from
    that sounds like somthing i need to do!!!
  10. #30
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by Mrk_Mickey View Post
    maybe clean your MAF with MAF cleaner
