Page 359 of 393 FirstFirst ... 259309349357358359360361369 ... LastLast
Results 3,581 to 3,590 of 3924
Thread: MK3 Random Thread
  1. #3581
    Nov 2015
    I am seriously considering this one OBDeleven diagnostic and coding app
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  2. #3582
    Mar 2014
    Bundoora, Victoria
    My car has the same port design as 2015 cars with OBD2, but it sure isn't compatible with any generic scanner. OBDeleven even implies that by only supporting cars from 1996 onwards. That's when VW supposedly started following the same communication standard as everybody else. 1995/1996 was the transition year and so VW fitted the new connector to some cars but did not upgrade the electronics inside.
  3. #3583
    Dec 2014
    My car pings super bad if I use anything less that 95. Ill only use 98 unless I'm flat broke and then I'll put a bit of 95 in
    Sent from my GT-I9305 using Tapatalk
  4. #3584
    Nov 2015
    Quote Originally Posted by stefcio007 View Post
    So it should work for all my cars other than the 96 Vento (which has a compliance date of 08/96 but a build date of 08/95), which is the vehicle I really need the Vagcom for. Back to square one and doing some more research for then. Thanks for the info.
  5. #3585
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by feenix74 View Post
    My car is in the same boat, compliance date is 96, build date is 95.
    I bought a cable that looks like this and it worked for me.
    Past - '95 VW Golf MK3 VR6
  6. #3586
    Nov 2015
    Cool, thanks for that. Seen those on ebay, I will grab one to give it a go.
  7. #3587
    May 2014
    Newcastle, Australia
    Quote Originally Posted by BurgundyMk3 View Post
    Do you think VW put the 95 octane or above sticker on just for fun?
  8. #3588
    Dec 2014
    Quote Originally Posted by cliftronix View Post
    Oops, quote didn't work. I was supposed to be replying to someone a few posts back.
    And even then I miss read the post (facepalm)
  9. #3589
    Mar 2014
    Bundoora, Victoria
    I'm not sure what you mean? I've been putting Shell Vortex 98 for a really long time (previously used BP's 98 ), just wondering if United 98 petrol is similar in terms of quality to Shell's.
  10. #3590
    Nov 2015
    I have always found I got better fuel economy using the Caltex Vortex 98 in the 1.8l CL. Even if I don't get the 4c/L off with the Shell V-Power at Coles Express, it worked out more cost effective to pay more per litre but the extra mileage meant that I saved myself a couple of dollars a tank.
    I have heard that the BP 98 is the best fuel of the lot but without a BP close by I do usually fill up with it.
