Page 344 of 393 FirstFirst ... 244294334342343344345346354 ... LastLast
Results 3,431 to 3,440 of 3924
Thread: MK3 Random Thread
  1. #3431
    Nov 2015
    Quote Originally Posted by browntown42 View Post
    What's the best way to paint the outside trim? it's cracking on the front bar and coming off on the rear bar. Should I just pay someone to do the roof, bonnet and trims all at once or is it a DIY job?
    If you are redoing the Dragon Green, it is meant to be a dark metallic green with a blue tint clearcoat which gives it a blue pearl effect. As the clear coat ages it loses the blue tint so you tend to lose the blue pearl effect, although the metallic green is still pretty good looking if you manage to keep it in good condition.
    I would suggest that if you have the spare money to get it done professionally.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  2. #3432
    Mar 2014
    Bundoora, Victoria
    right sorry, keep forgetting you have the 096 *facepalm*
    Good point.
  3. #3433
    Mar 2014
    Bundoora, Victoria
    so, I did everything with regards to servicing the transmission. Checked the level 4 times, correct temp, everything, after changing the filter and gasket. The trans slips more than before though, I'm lost as to what has happened. I've reset the fuzzy logic of the controller and given it a bit of time to re-learn. I've found that it sometimes drops while turning. I had this happen before though but not very often. It sometimes has trouble engaging first. Once the car is rolling it changes gears like before.
    I have a feeling that there is not enough fluid and it goes to one side while turning hence slipping, but if that were the case then why is the fluid correct when I check?
    Anyone have an idea and what's happening?
    Past - '95 VW Golf MK3 VR6
  4. #3434
    May 2010
    Stefcio, Temp is measured once warmed up?
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
  5. #3435
    Mar 2014
    Bundoora, Victoria
    Speed, yes, I measure the temp once warmed up and start checking the level once it's in the correct range. Maybe the fluid is too new and the car is just used to the old fluid?
    Oddly, it performed well for a small incline today from a stop position, no slipping.
    Maybe it just needs time.
    Edit; vagcom is not throwing any error codes at all for trans.
  6. #3436
    May 2010
    Quote Originally Posted by stefcio007 View Post
    New fluid SHOULD be better but like you said, maybe you need to give it more time.
    I'd resist any hard launches until your sure it's sweet.
  7. #3437
    Mar 2014
    Bundoora, Victoria
    I'm going to do another fluid level check, last time I did the check it needed more fluid and it helped. Maybe it's still not enough.
    Being careful though. vagcom seems to sometimes change +/- 4°C when reading so it's a little tricky.
  8. #3438
    Mar 2014
    Bundoora, Victoria
    Did another fluid check, correct temps, engining running. Went well. Going to test drive later tonight and see how it goes. Seemed that it took on more fluid. Last time more fluid was added in the end the car slipped a lot less. Here's hoping this was all it needed.
  9. #3439
    Mar 2014
    Bundoora, Victoria
    Car back to normal, happy days.
  10. #3440
    Mar 2015
    Quote Originally Posted by feenix74 View Post
    I was actually thinking about going the black textured trims to match some flares I bought as well as the guard, bonnet and roof need to be done. Almost snagged a 98 golf in the same green with no panel or paint damage but the guy wouldn't reply after one text, such a miss Must of sent it off to the wreckers
    Mk3 2.0. Mk3 VR6 CC. Future Mk2?
