this is good discussion, i like it!
i would think with an FI engine with a turbo would require a little more maintenance than a supercharged one, just because of the heat generated by the turbo getting so hot would make the oil turn acidic quicker causing the engine to wear. so i suppose a turbo engine would require oil changes more frequently, would that be right?
supercharger wouldnt get as hot i'd imagine.
i think i heard somewhere when i was younger that it puts components under less stress to make power at higher RPMs. like for example a stock 1.8t motor, makes its highest torque at around 1750 rpm. now wouldnt having the piston forced down with an explosion at such low rpm make give more stress to bearings in the crank and rods and such for a longer time, than making the same power higher up, at say 4000rpm? maybe thats not a good comparison.
i suppose making the power higher up might be putting less stress on the bottom end from torque, but more stress on other components, like rings, because they are doing that same movement with a force for a shorter period of time be much more often...
and just to clarify either NA or FI, i wouldnt be looking for massive power, just a fair bit more than i have now and a nice sound.
i wouldnt be skimping on any parts either, pretty much everything would be replaced, bringing km's back to zero, on the engine and maybe the gear box too.
if FI i was thinking a supercharger at around 6-8 pounds would do it, with some cams, in a three litre would do it nicely.
if NA i was thinking, still the three litre, cams, good p&p job, and maybe 10.5-11:1 compression, so not crazy compression but a bit of a bump.
either way i go, FI is going to be more expensive because i'd have to fork out for the parts of rebuild, and on top of that the FI parts.
-steve
