Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: Engines under forced induction
  1. #51
    Sep 2006
    Australia?
    Quote Originally Posted by Bug_racer View Post
    Kinetic wont deal direct with people here cause our ecu's are different and they will not deal with people here on an individual basis . I'll have an Australian spec ecu available shortly . The stage 1 kits here will be approx $4500 with the current exchange rate .
    Can you please elaborate on this?
    What kind of turbo kit is it and what does it consist of?
  2. #52
    Closet Diesel Owners Club President.
    One point to consider is that turbo cars generally produce far more torque down low than N/A cars of similar capacity.
    Therefore they don't have to rev as much and this places a lot less stress on the engine components in the heads. Revving high wears your heads out much faster than 100,000 of low rev action. The springs will be thrashed after 100,000 if they are revving higher all the time to get moving.
    Most turbo cars also have a stronger piston/rod combination and usually better head studs as well. This means they won't be under much stress.
    The question of longevity for turbo cars is tuning and boost. At a certain ratio of boost turbo engines longevity goes down a lot. Eg twice factory amount on subaru's and you have to start rebuilding the motor for head gaskets every 30k as a precaution so they don't pop.
    A turbo engine is like an 80kg guy who does weights lifting 100kg vs an 80kg guy who does no exercise lifting 50kg. The guy doing 100kg will probably still do more exercise than the unfit guy (N/A). Like the turbo diesel toyota hilux's that get more than 500,000k's on their first motor before a rebuild. I know this as I used to work for toyota australia.
    *Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
    Economy at 100kph =5.5L
  3. #53
    Jul 2007
    Rowville Melbourne
    Seems to make sense to me.
    How strong does a piston rod combo really need to be to deal with low to medium levels of boost? thoughts?
    on a vr6, on vortex obviously alot of people are running vr6t's and sc's on stock blocks, and they seem to go just fine.
    obviously thats not built for forced induction, but does an engine really need forged everything to be built for forced induction?
    -steve
  4. #54
    Sep 2007
    forged internal components will be under the same stress as stock interals however due to different piston design - ie surface area shape and material, they will have a higher maximum allowable stress, and hopefully will not succumb to yielding from heat and the higher force generated from boost.
    87' MK2 GTI
    13' MK7 TDI
  5. #55
    Jul 2007
    Rowville Melbourne
    so for around stage 2ish, like around maybe 250-280whp (no i cant be bothered workin out what that'd be in kW), would forged rods and pistons be justified? or a little over the top for a fast street car?
    -steve
  6. #56
    Dec 2007
    Ermington, Sydney
    I'm not actually sure about this so it'd be nice to get an answer...
    I was always under the impression that forged internals were for cars making respectable power. That is, cars that aren't just a stage 1 bolt on turbo kit and exhaust. I'm thinking more a stage 2 with decent mods or a basic stage 3...
    can someone confirm?
  7. #57
    Jul 2007
    Rowville Melbourne
    thats was i was thinkin too man
    dont see the point in gettin forged super strong internals for making stupid power in a front wheel drive car anyway. 4motion on the other hand, hell yeah, go all out and make as much power as you want!
    -steve
  8. #58
    Sep 2006
    Australia?
    Quote Originally Posted by Shteifen View Post
    -steve
    What for I'm looking at a kinetics kit at the moment that is with a T3/T4 turbo looking at around 300whp without a front mount.
    And all that is, is the bolt on kit.
  9. #59
    Jun 2007
    Eastern Suburbs Melbourne
    heaps of guys on vortex run big numbers with standard bottom ends.
    I've heard things like 400HP, but not 100% sure. .. Anyone have some links??s
    i like volkswagens
  10. #60
    Jul 2007
    Rowville Melbourne
    ya they run real big numbers over there. i was just wonderin if there is any proven way to make your bottom end stronger other than doing a rebuild, cos i already plan on that.
    are there any sorts of bearings that would be more suited for forced induction?
    any sorts of oils?
    valves? (other than just big ones, i mean the metals they are made out of)
    is it a bad idea to reuse on rods? i know they wouldnt be as strong as forged ones (actually i cant remember which parts of a vr bottom end is already forged, though im pretty sure something down there is. maybe the crank or something, i forget)
    -steve
