Results 1 to 10 of 16
Thread: just a few quick Q's about my mk2.
    Nov 2006
    Ro-town, Melbourne
    hey there everyone!
    i haqve a few questions about my mk 2 and i rekon heres the best place to ask...
    i have had some trouble with my thermofan siezing, so i replaced it with a porsche 996 unit we had spare at work, and it worked great for about a day. now it is siezed aswell.
    has this happened to anyone else?
    it happened in winter, so i didnt really stress - warning light never came up, just drove around looking all cool in my mk 2
    then a few weeks back my thermostat housing cracked, and was leaking coolant. just topped it up here and there as it was only a tiny leak.
    last week it pretty much gave up, and i have replaced it - and everything is all good again - besides no thermofan.
    so the questions are:
    what is the normal operating temp for a mk2? when i look on my trip computer? - i want to kn ow when im running too hot.
    does anyone run aftermarket fans?
    when i buy my aftermarket fan (or maybe another porsche or bmw one from work) how do i wire it up with a switch in the cabin? do i need a relay? etc?
    i want to avoid using the current circut, as i dont know why the fans are blowing - may be the circut, may be somthing else
    thanks in advance guys
    ---Damien
    Tagedeze Heezy
    1991 Mk2 GTI (Auto)
    1968 Automtic stickshift Beetle
    syncro Guest
    The cut in temp may be written on the switch. Should be a two speed.
    Just get a new Golf 2 fan and it will last for years.
    The trip computer temp is the oil temp not water. Anything up to 110 degrees would be normal on the road.
    The temps the switches operate at are on the body. Usually on at 105 I think and off at 95???
    Should be no need to have a switch inside unless you are doing some track work and want to deliberately start the cooling early.
    There are single and dual speed fans on MK2s. Single speed has 2 wires dual speed has 3 wires.
    syncro Guest
    Aussie ones have two speed.
    Camden, Sydney
    Quote Originally Posted by syncro
    Unless they have broken before and been replaced with a Mk1 single speed unit. I see that a lot, ghetto stylee
    May 2006
    When you say the fan seizes do you mean the motor gets locked up? Is it still locked up after you remove it from the car? If the fan motor siezes and you replace it and that motor seizes too then I would think the cause is unlikely to be electrical. Even with dead windings a motor ought to turn. If there's a crook bearing you'd hear that before it failed too. I'd be wondering if there is a mechanical problem like a damaged fan cowling or something that impedes the fan from functioning. But probably a good idea too to check you have the right fuse on the fan.
    If the fan spins ok but the problem is that it just doesn't come on when the motor gets hot then the first place to look is the electrical connection on the fan switch on the lower near side of the radiator. Stuff drips on the connector.
    But is it possible the motor isn't getting hot enough? In my car the fan only comes on under extreme conditions. The best test is to let it idle with the aircon running. Should come on then.
    syncro Guest
    Quote Originally Posted by Golf Loon
    Typical Golf owners
    Then they complain 'cause they don't have the correct plug to fix itn:
    Aug 2005
    Prahran, Vic
    fan comes on with the aircon anyway.
    does anyones fan come on much? i replaced my thermoswitch a couple months ago and ive never heard the fan come on (only comes on with the a/c).
    is the fan meant to blow air onto the radiator, or blow air away from the radiator (and towards the motor)???
    syncro Guest
    Towards the motor.
    Always worth checking if you have butchered wiring.(Standard equipment on S/H Golfs)
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    my fan when 2 weeks after i got it.lol..........
    now runs 2 n14 GTiR pulsar fans
    Cheers, Benny
    www.axesent.com.au
Similar Threads
  1. quick replay window
    By deemoE36 in forum User tips and Forum Suggestions
    Last Post: 28-01-2007, 07:14 PM
  2. Quick Racks (again)
    By Bluerex in forum Mk1 Golf
    Last Post: 06-09-2005, 07:47 PM
